Question about Euro-Pro Shark GI490 Iron
I have no power to my shark iron model 1490
I have no power
Posted by Dennis Carter on
Checked fuse on swan steam 2400w no power to on light
Double check your outlet with another appliance to be sure it has power. If power wire close to plug may be comeing apart.
Mar 08, 2015 | Irons
Power up problem
Would probably be best to buy a new iron, not powering on, would indicate a internal problem, really in my opinion it would be best to buy a new one. without knowing more about the iron you have..
Jul 22, 2008 | Irons
How do I fix my iron because it is not turning on
1. If there is sign of power (e.g. light is on), the heating element may be broken.
2. If there is no sign of power, check the power point (socket), iron power plug, cable and the power on switch. If everything is fine, you need to get it repaired.
Jun 09, 2014 | Irons
Power steam elite boiler screw is stuck
Morphy Richards Power Steam Elite boiler screw
Mar 16, 2013 | Morphy Richards Irons
Iron doesnot get hot onlyplatform
Try to open the electric iron and locate the thermostat . Secure the electric iron against any metal object that may cause electric shock or short circuit and plug it to a power source. Slowly adjust the temperature and using an electric tester check the power before the thermostat and after the thermostat. If there is a power before the thermostat and has no power after the thermostat then your problem is the thermostat replace it with a new one.
Jul 14, 2011 | Euro-Pro Irons
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
If using with a power strip or extension cord, how many amps does the iron pull -- it is 1700 watt the kind I have
Power = Current x Emf
Current = Power / Emf
Current - Amps
Emf - Volts
Power - Watts
Current = 1700 watts / 120 Volts = 14 Amps
If you live in Europe then -
Current = 1700 watts / 240 Volts = 7 Amps
Be sure your breaker and extension cord are rated for the amperage.
Nov 19, 2010 | Tefal UltraGlide Easycord FV4256 Iron
The iron seems like it is on but no steams come out I will mess with the wire and then too much steams comes out and I have water stains
Power Cord is bad and power cuts on and off not allowing the proper heat. When power cuts off you lose heat and the iron fills up with water and not steam then when power returns you have to much steam.
Jul 17, 2009 | Rowenta Irons
Sunbeam iron won't power up.
I bought a new replacement iron at Sears for $17.99. It is not worth fixing my old one .
Jun 17, 2009 | Sunbeam Irons
Euro-Pro Shark GI490 Iron Logo
285 people viewed this question
Top Euro-Pro Irons Experts
Sheldon Dedek
Andrew Taylor
Andrew Taylor
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
