Question about Jet 2 HD for 350 lbs, Power Chair, Wheelchair Scooter Wheel Chair
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
Jason Smith
    Sergeant:
  • 182 Answers
Sometimes the batteries for powerchairs sit on the shelf for quite some time and can be low on charge. I would recommend if you have a voltmeter taking a reading on each battery, have to disconnect terminals first. if they do not have at least 12.25 volts I would put them on a slow charge and see if that does not correct the problem
Posted on Sep 28, 2015
Claude Kayser
    Top Expert:
  • Pride Mobility Master
  • 9,098 Answers
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Jazzy 1143 power chair
well if u need the charger on then batterys are dead and need to be recharged,or have the batterys checked make sure they are ok by testing a load on them at a local auto parts store for free,if no good make sure u get same type of battery and make sure it is a gel battery not a acid battery
Sep 04, 2013 | Electric Health & Beauty
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Hi there...I had not used my Hoveround MPV4 scooter for over a year and when I finally went to use it, the batteries were no good any longer as they would not hold a charge...so I just bought two brand new...
Hi Pam,
The new batteries should work right away. (Your old ones had gone solid from sitting for so long- charge the new ones at least once a week to keep that from happening, even if you are not using your power chair.)
You may want to check all of the connections to make sure they are tight especially on the battery posts, also make sure the fuses are not burned out. It's recommended to run the new batteries into the red (fully discharge) then let them charge for 8-12 hours to make sure the batteries get a full charge the first time out, but if you haven't done that, it should not cause any flashing lights.
You said that green lights were flashing (assuming on the controller); if all 10 bars (3 red, 4 yellow, 3 green) are flashing that indicates a poor battery connection. 9 bars means you need to do a brake reset. Check page 51 of your manual for controller light codes or check this link: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
If you have any other concerns, let me know. Good luck!
Oct 12, 2010 | Health & Beauty
Installing Kenwood KDC-MP345U into a travel trailer. Trailer is pre-wired for deck. Have Orange (hot) & White (ground) from trailer converter to deck. Hooked up yellow (battery) wire from harness to...
the power terminals from the trailer arent direct connected to the battery terminals.when you are plugged to the mains the battery is charging and disconnect [via a relay perhaps]the orange terminal from batt+.try to make anew connection from the trailers battery terminals with a new fuse separated from all trailers circuit'use 2-2.5 mm*cables and a 15amps fuse.connect the yellow and red to+batt and black to- batt.
Jun 05, 2010 | Kenwood Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Need to install new radio
This should Help:)
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
RR Speaker (-) BLACK
Oct 25, 2008 | 1991 Honda Accord
Radio codes
LR Speaker (+) RED
RR Speaker (+) BLUE
Oct 18, 2008 | 2003 Chevrolet Silverado 1500
I have a 1959-1962 Honda C102 Super Cub 50cc Scooter, with electric start, that has a 6 volt system, that I am trying to get running. I have a new 6 volt battery, fixed a lot of wiring problems, and was...
large wire off starter will go to positve battery, the small yellow/red wire should go to the starter solenoid, and the battery should be hooked up like a nornal setup please rate -jeff
Sep 01, 2008 | 1995 Honda Civic
Jet 2 HD for 350 lbs, Power Chair, Wheelchair Scooter Wheel Chair Logo
120 people viewed this question
Top Pride Mobility Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Pride Mobility Vehicle Part and Accessory Expert? Answer questions, earn points and help others
