Axle nut size? - Taurus Car Club of America : Ford Taurus Forum
www.taurusclub.com > ... > Suspension, Handling and Brakes
Jul 23, 2011 - 8 posts - 5 authors
1996 Mercury Sable front axle nut. I have read that the size is 30mm but the socket that I rented (30mm in a ... 2000 Duratec SE White Wagon
Axle nut torque question. - Taurus Car Club of America ...
May 4, 2012
CV Axle nut size
Dec 9, 2011
Why Does The Axle Nut Need Such A Big Torque
Dec 7, 2009
2000 Ford Taurus Front Wheel Bearing And Half-axle ...
Apr 18, 2009
More results from www.taurusclub.com
SOURCE: front rotor nut
hi out of curiosity? are wanting to renew thebrake disc/rotor ? or the actual hub that rotor fits to ? as not usually necessary to have to remove hub to change rotor ? unless the rotor is bolted to hub from the rear ?
SOURCE: how do i changs axle shaft on a 2001 toyota echo?
To remove the axle, losen axle nut with tire on the ground if possable, much easier without air tools. Disconnect strut at top of spindle, outter tie rod, and lower balljoint. Using a prybar pop axle out of transaxle. Some of these steps may be alittle different for your vehicle, these are general directions. If you are compitent enough to do this job then these steps will get you through it. If these steps confuse you pay someone else to do it.
SOURCE: why is it a big worldwide secret what size the axle nut is
1 11/16 odd size i know. check with Sears or Harbor Freight.
