SOURCE: pxe-e61:media test failure,check cable
i have same problem in toshiba satellite a00-13r .. (media test failure ...) i have replaced hard disk and cd-rom .. now its working
SOURCE: PXE-E61: MEDIA TEST FAILURE, CHECK CABLE
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
SOURCE: PXE-E61 media test failure check cable
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
SOURCE: My Toshiba says PXE-E61:Media Test
check the boot sequence in bios
make sure that the first boot device is your HDD and disable the network boot
Hi Joseph Jackson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
