Question about Jandy Pool & Spa
My Jandy system is marked main drain but no labe for backwash is main drain the same
Jandy stealth
Posted by Terri taylor on
1 Related Answer
joespools200
  • 246 Answers
SOURCE: jandy filter CL580 How do I backwash this filter
cl580 is a cartrige filter , do not back wash
Posted on Oct 16, 2009
Is there a reset button for a jandy stealth 1.5HP pool pump
it kicks out breaker try turning the motor shaft if still doesnt work need new motor
Jun 27, 2012 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
Jandy/Stealth Pool Pump motot
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
May 02, 2010 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
My jandy stealth pool pump stopped working. it just hums when turned on. The model # is JHP1.0.
ONE OF THE CAPACITOR MAY BE BAD CHANGE THEM BEFORE MOTOR REPLACEMENT .CHECK IMPELLER FOR ANY DEBRIES BLOCKING
Sep 23, 2009 | Jandy Stealth Pump 1 HP 115/230v
De filter pressure too high water is cloudy
backwash the filter from main drain until sight glass is clear-this will reduce filter pressure. After backwashing return gate valve to filter position, then filter from main drain only. check water chemistry. add a clarifier to water
Jul 28, 2009 | Pentair 3/4HP Pinnacle High Performance...
Pool & Spa Logo
97 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Marvin
Marvin
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
