Question about GE Microwave Ovens
Need to know how to take down this under cabinet model for replacement?
Replacing with GE model # jvm3160rf2ss
Posted by Sandra Tillman on
White Bai
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Two or three screws on the top of this microwave (mc), which are located on the top cabinet. Loose them first. Also the bottom of the mc is attached to a metal edge against the wall. Need at least two men to hold and unload it from the wall.
Posted on Sep 28, 2015
Can you provide under cabinet mounting instructions for GE Microwave part WX4-A19?
To mount it under a cabinet, you have to have the under cabinet install kit; you'll find that here: Under Cabinet Mounting Kit WX4 A019 GE Appliances the kit does include instructions. You can't mount it without the kit.
Dec 12, 2015 | GE Microwave Ovens
I have a GE jvm1790 microwave that when its pluged in, the magnatron fan runs with the interior light is on constantly. I can't start either the microwave or convection. Everything stops when the door is...
The megatron tube is not working. The microwave should turn off when the door is opened for safety. If it is still under warranty, return it. If not, you may consider replacing the unit. I know its expensive, but its just taking up cabinet space tonight.
Nov 06, 2009 | GE JVM1790SK Convection/Microwave Oven
I need to know how to uninstall a GE spacemaker microwave oven model JVM250av001...any one out there know how..?
Put padding on the floor near by for a landing zone. Disconnect the power in the cabinet above. There are two screws in the upper cabinet that support the front. There is a wall plate that supports the back. When the two front screws are removed you will need to be supporting the microhood or it will fall. A strong assistant is nice to have. I like to have the stove out of the way so I can get under the microwave to support it. Once the front two screws are removed, tip the front down, pull the cord out of the upper cabinet. Then lift the back slightly to remove it from the channel on the wall bracket. Set it down Done.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave GE Model #JE1640WB - Makes noise when
Magnetron is done. This part heats the food. GE microwaves tend to have them stop working quite frequently. They basically make up the majority of the cost of the microwave, so instead of replacing the magnetron, you would be better off getting a new microwave.
Benjamin
Jul 15, 2009 | General Electric Microwave Oven
Will the template for JVM1790 be the same as earlier GE models?
Make your own template of the holes in the top of your cabinet and lay it over the new unit and see if they align. As long as your replacing GE with GE it probably will work.
Oct 04, 2017 | GE JVM1790 1000 Watts Convection /...
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
GE spacemaker model # JMV1640BB002
magnatron went bad need new one, cheaper to buy new unit
Feb 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No sure how to remove oven from under cabinet in motor home
You can download GE owner's manuals and installation instructions here.
If you need further help, reply back with your model number.
Dec 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
Microwave Ovens Logo
79 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
gbob59
randymanfive
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
