[email protected] Posted on Sep 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i clear error f2 70 on sharp ar 5618 - Sharp Office Equipment & Supplies
Jeff Watkins
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 33 Answers
  • Posted on Oct 25, 2015
Jeff Watkins
Expert
Level 2:
New Friend:
Night Owl:
Answers
33
Questions
Helped
15849
Points
165
Service Manual SHARP AR 5618 5620 5623 SME honestly I did not see this code in the owners manual but it should have a number you can call to ask how to clear it. I've noticed a few people have asked this question for this specific product but haven't gotten any answers. If you do find the solution please post it for people with the problem in the future :)
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Oct 30, 2008
SOURCE: My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Warrick Lee
  • 32 Answers
  • Posted on Mar 25, 2009
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Anonymous
  • Posted on Jun 06, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Anonymous
  • 11 Answers
  • Posted on Oct 05, 2009
SOURCE: sharp ar 405 u2-11 error
Content Counter check sum error (EEPROM)
Detail Checksum error in counter data area
Cause EEPROM defective
Control circuit hung up due to noise
Defective EEPROM access circuit on
PCU PWB
Check Check EEPROM for proper set-up
and To prevent the erasure of counter data
remedy and adjustment values, write down the
counter data and adjustment values by
simulation. (If there is a printer option,
execute SIM23-1 and note counter
data/adjustment values.)
Clear U2 trouble with SIM16.
Replace PCU PWB.
Anonymous
  • Posted on Aug 10, 2012
SOURCE: Sharp Copier AR-286 Error Code H4-01
# * C* start 14 >1 Start
Hello sir, display error code L6 sharp copier AR-5618 not working. how can i clear it? i,m rathnasiri from sri lanka
https://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=54
Polygon motor lock detection
http://www.fixya.com/support/t8173221-displays_l6
Quoting:
Mike Beeston
L6 = Polygon Motor Lock Detection
The Polygon Motor spins the mirror which writes the laser signal to the drum.
If switching the machine off/on doesn't cure the error code the only other thing you can do iw just check that all the connectors are plugged in correctly. Polygon Motors do fail and when they do all you can do is replace them. Quite often they will screech or rattle in the run up to failure.
Hope this helps.
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
The following video should help also;
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
2helpful
F2 70 error code on sharp ar-5618, how can i resolve it.
i have sharp ar 5620n it is showing error f2-70 what might be the course
61helpful
4answers
1helpful
3answers
How to reset sharp AR -5618
how to reset the toner chip as it is costaly
F2-64 on sharp AR-5318
sharp ar 5618 zerox machine in f2 64 error solution
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
