Computers & Internet Logo
Question about Dell Inspiron Computers & Internet
How to bypass/delete administrator on dell laptop?
Posted by helen D Franco on
Account Administrator Delete
You have to have at least one Administrator account. You can however choose to call it something else. Create a new Administrator account and give it your favorite name. You cannot bypass the administrator restrictions unless you are an administrator.
tip
Dell Password Reset Helper
Are there some ways on Dell password reset if I forgot Dell system password or Dell laptop password for such as Dell Inspiron, Latitude laptops and Precision Workstations? How can I reset Dell password with Windows 7, XP, 2000, Vista, etc.? Urgent to solve the problem! I have to access my PC for vital files! Next, let's take care of the following common methods for Dell reset password.
Method 1: Use Dell password reset disk to reset password Dell laptop
The method is only for users who created such disk before forgot Dell password.
A. Create a password reset disk
a. Insert a USB Flash Drive or CD/DVD into driver.
b. Open Start - Control Panel - User Accounts and Family Safety - User Accounts.
c. Select "Create a password reset disk" on the left pane, and then "Forgotten Password Wizard".
d. Click "Next" and follow the Wizard to create password reset disk.
Now, you need not know the old password to recover lost Dell password. With the disk, you can safely bypass Dell password now!
B. Reset password Dell laptop with the created disk.
a. Click OK and close the message box on the password incorrect prompt interface.
b. Click Reset Windows Password and insert the password reset disk.
c. Follow the Password Reset Wizard to create a new password.
If you need not opt for this method to help you bypass Dell power on/login password, please share it with your friends who own Dell laptops or netbooks.
Method 2: Dell password reset from accounts with administrator privilege
We can bypass Dell password by available accounts with admin rights, the built-in (default) administrator account included. Take the steps:
a. Press Ctrl+Alt+Delete twice when PC starts.
b. When Log On to Windows dialog box appears, type Administrator in the User name box and the administrator password in the password box. And then click OK. Or you can directly click Ok if you don't set password.
c. Click Start > Run > Type control userpasswords2 > click OK.
d. Choose the user name that you want to reset the password for, and then click Reset Password on the Users tab.
e. Set your new password and click OK on the Reset Password dialog box. And then click OK on user tab.
f. Restart the Dell computer, and then try to login with the account reset.
Method 3: DIY a bootable CD/DVD or USB Flash Drive Dell password recovery disk
We just need a PC with optical Driver and password recovery software to remove lost Dell password. Ainorsoft Windows Password Recovery is welcomed by large amounts of Dell computer users! Then the procedure to create Dell password reset disc is as following:
a. Download and intall Ainorsoft Windows Password Recovery then burn its .iso file into a blank CD/DVD or USB Flash Drive with an accessible PC;
b. Boot the burned CD/DVD or USB Flash Drive from the PC lost password;
c. Reset the new Dell password.
It will be sure that we will never worry about Dell password reset for versions like Inspiron, Latitude, Vostro, etc. with Windows 7, XP, Vista or 2000, etc.
Dell precision m70 administrative password is is locked. ehat can i do
Use a program called Kon-Boot
it will bypass all Windows security altogether
2answers
1helpful
2answers
I forgot my administrator password to my Dell Inspiron 1526.
If i forgot windows password, how do i bypass windows password?
Step 1: Download Bypass Windows Password software and install it.Step 2: Burn a bootable Windows Password Recovery CD/DVD or Windows Password Recovery USB flash drive with the program.
Step 3: Reset Windows Administrator Password to blank with the burned CD/DVD or USB, then bypassing windows password and regain access to your locked computer.
6helpful
2answers
Reset admin password dell inspiron b120
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-b120-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
1helpful
Need to delete bios password on a dell latitude cpi r400gt
I have just done this. One needs to dismantle the laptop first. Solder a push button switch with extended wires across pins 4&5 of the serial eeprom 24c02. Then reconnect the screen, keyboard & a/c power pack. with a tooth pick press power on switch whilst holding push button on. When the factory mode screen comes on release the push button. Next go to bios setup F2 and ALT-p to the password page. Now enter your new password this will overwrite the old pass word. My approach is slightly different to this following method as it is les likely to brick the laptop.
http://www.archive.org/web/2003110302606
2helpful
2answers
Bought a dell inspiron 1526 laptop from a pawn shop. but can't access harddrive due to a password, is their anyway I can bypass it or delete the password on the hardrive.
Go to: http://dell-inspiron-1526-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
2answers
How do you bypass a system authentication password
Depends--if you are using Win XP, you can start in safe mode and choose administrator.
Otherwise, you can't
Clive
Clive
Steve Sweetleaf
Steve Sweetleaf
