SOURCE: Bought internal harddrive and don't know where
hi, sorry to tell you this but that model of dell desktop does not have sata ports or sata power connectors and has no spare drive bays to mount the hard drive either , you would be best to try and return the drive and purchase an external hard drive and connect it to your PC via the usb socket .
Hope this helps
SOURCE: My Acer laptop has locked
After doing a bit of research and some experience, it sounds like your "friends" have set a password on your laptop for security/joke/accident. The have then either forgotten it or not known what it is and then tried to enter it in again but failed 3 times. so now you see that message.
To unlock you will need go to a site such as this that explains how to fix:
http://www.acerlaptoprepairs.info/aspire-5534/remove-hddbios-password-utilities.html
You may have to go to the exact page for the model of your Acer.
Your only alternative may be to send it too Acer themselves:
http://acer.custhelp.com/app/answers/detail/a_id/2732/kw/password/session/L3NpZC9FSTQ5N1Ruaw%3D%3D
Good luck.
SOURCE: My daughter's Aspire One is
This password is a BIOS password and to reset it you'll need to go into BIOS and do it manually.
If the password comes up before any other loading screens then we'll need to flush the BIOS password cache, but hopefully we can solve everything by going into BIOS.
To enter BIOS hit the F2 key repeatedly as the computer boots up. You should enter BIOS after the first loading screen by Acer. If this does not send you into BIOS, try the DEL and F1 keys. You might also need to hold the F2 and DEL keys together. Once in BIOS find where you can set the password and reset it or enter a blank password as your new password.
If you can't access BIOS or are prompted for a password once you enter BIOS, try the following methods to flush the BIOS password cache:
1. Contact Acer support and ask if they have a backdoor BIOS password that they will allow you to use.
2. Send your laptop to Acer to have them reset the password manually, although this takes an undisclosed amount of time and I believe they will make you pay about $100.
3. If you don't want to pay Acer, open your laptop and locate the motherboard. On the motherboard there is a CMOS battery, if you don't know where this is use your PC manual. Remove the battery for an hour and then place it back on the motherboard. This should reset the password. After this turn on your computer and continuously hit F2, or whatever key you find opens BIOS, while the computer boots. This will reset all your BIOS settings so it may take a few minutes to open. After it is open, just exit BIOS and everything should be working properly.
Thanks for using FixYa and good luck!
