I got this thing a couple of days ago to replace an older model with pretty much the same features auto set, dual alarms, that had started to randomly reset the time zones - not good for making it to work... I noticed that it had been updated and the control redesigned, so there were some more bells and whistles. Big mistake - HUGE! The instructions were too small to read, so found the manual on-line, enlarged it to 200%, which I could then see, but it wasn't written in any kind of logical order. Altogether completely and unnecessarily counter-intuitive and complicated. Took me HOURS to set up, and I'm no dummy. I have to go back to the instructions just to change the alarm or even change a radio station. Back it goes. So now I'm trying to find a suitable replacement - auto set and dual alarms are required, and it would be nice to have digital tuning instead of a dial. Don't want or need projection, a weather report, presets, a usb port, or an iPod charging station. There are some units out there that seemed ok, and were well-reviewed, but all the negative comments were about the directions, difficulty of set-up, multiple-function, unmarked buttons that needed to be pushed in particular combinations to get anything to work, and the complexity of changing settings. Sorry for the long rant, but I've been searching all day, and the 5 - 10 top-rated models all have this same issue! Any suggestions or solutions out there that don't cost $300+, or are only to be found used on ebay? Many thanks for your help! Marianne
SOURCE: Non-responding buttons
maybe you have defective crack board! or lost contact at the board! or clean all tact switches.
SOURCE: Emerson Smartset alarm clock
Hi - You can download the manual from the link underlined in blue below:
CKS3528
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
SOURCE: Smart set alarm clock - resetting instruction
First, make sure the time is set correctly – Eastern Standard Time (EST) is the default
Press the Alarm Mode button – it has options for Weekend, meaning Sat and Sun only; Weekdays (Mon-Fri), and Everyday
While holding either the ALM 1 or ALM 2 button, press up or down to set the correct wake-up time
Release ALM 1 (or 2) when you are finished
Here is a link to the manual:
http://www.emersonelectronics.ca/emerson/en/product/view/17796
-Tha Mp3 Doctor
SOURCE: My Emerson IC172 Clock Radio won't recognize iPod
For this type of problem you will need to talk to Emerson Customer Support. They will know if the functions you want will be available to you with the operation of the Clock/Radio and your iPod. The telephone number for the Emerson customer support is 1-800-909-1240. You can call them during the hours of 8am-4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information help you solve your problem. Thank you for using FixYa and have a nice day!
SOURCE: Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
