When I try to program my comcast remote none of the codes provided will sinc the remot to my tv. This remote is provided with my cable box.my remote is xfinity voice comand.
Https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
wholesale Samsung BN44 00715A L55G2Q ESM PSLF151G06A Power Supply Used
If it is the original remote control to Comcast Cable box; there is no need set it up with a code. It might have been already set. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
SOURCE: need a remote control code
hi,i had the same problem and found out that the samsung remote codes worked,try that.
SOURCE: programming comcast remote
the codes for the remote to access a Proscan TV are as follows: 11447, 10047, or 11347. I assume you know how to get into the remotes coding mode, but if you don't Here is how you go about it press setup, then press and hold the TV button until the light flashes then input one of the code sets, then if you get a confirming flash hit the power button if the TV turns off your golden if it didn't repeat the cycle with the next set of numbers I gave you. if after you have tried all three numbers you still can't get the TV to react to the remote you will need to call 1-800-COMCAST and speak to someone on their technical staff.
SOURCE: What is the Comcast remote code
Comcast has a web page with the newest codes. If the codes listed won't work, the page tells you how to code scan.
start here:
http://customer.comcast.com/remotes/ Comcast Remote Codes Program Your Comcast Remote Control
SOURCE: I need the comcast remote code for a Proscan LED TV 40" PLDED4030A-RK
Try these: 10047, 10466, 10747 or 11922
