Question about Frigidaire Ovens
Have problem with Frigidaire cooking range
The control board was bad. Changed once and last for one month. Went bad again and this time last for a week and getting a code F15 or F99. could be some thing else bad. May be another relay. The top works fine but the oven is not operating. because the board in not functional. Please help. Thanks
Posted by Tariq Riaz on
5 Related Answers
Amigaman
Gerald Griffin
  • 248 Answers
SOURCE: Oven does not maintain temperature while cooking.
Is this a gas unit? If so you might have a weak oven igniter.
Posted on Nov 24, 2007
Anonymous
  • 1142 Answers
SOURCE: Gas oven stopped working
Sure i will be able to provide you solution
Posted on Apr 15, 2008
douglas smith
  • 1462 Answers
SOURCE: Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Posted on Sep 22, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
Anonymous
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Posted on May 31, 2010
How to test oven control board on a Frigidaire FEF366DBE?
Hello Shawn Lloyd, thank you for your post!
I see that your Frigidaire range blew the breaker to your home out and now the oven will not heat up properly. There is not information provided in order to test the control panel I would recommend having a professional technician for proper diagnosis and repair. The technician will be able to use appropriate tools in order to verify the control panel is working properly. -Matt
Nov 16, 2014 | Ovens
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have an Electrolux Frigidaire Self Clearning Convection Oven. I was cooking yesterday when it went off and I cannot get any heat now. The oven still lights up when I turn it on. The fan still wor
Hello - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Display shows PF-time of day flashing on Frigidaire range.None of the buttons respond. Rene
Try unplugging it to reset the main control board witch most of the time its your clock.then push enter.if don't don't work then your clock (main control is bad .or if it has a touch pad it could be bad.call repair clinic .com at 1-866-822-0890 or 1-800-269-2609 and order parts there.they can tell u how much
Nov 08, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
OVEN WILL NOT BAKE , IT WILL BROIL
I have the same problem, I took off the back panel and noticed that the EOC (electronic oven control) board is blackened and most likley need to be replaced. My wife was cooking a pizza and she smelled a burning plastic smell, she looked in the oven and saw the pizza on fire and smoke bellowing from the control panel area. So i unplugged the oven and saw the circuit board did start on fire and fortunatly it went out before serious damage. No matter what you set the oven on the display shows it as being correct, but only the top element comes on and it is on HIGH!!!! DO NOT BUY FRIDGIDAIRE!!!!
Dec 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My Frigidaire FEFL79GSA cooking element is intermittent. Last night it went to high although the control knob was on low and would not turn off when the knob was turned off. I had to turn the breaker off...
I'm banking that infinite switch is bad (the knob) but there could be other issues. If it's just one burner doing it then I would assume the switch, but if not then I would get a technician.
Hope this helps, good luck...
Dec 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire stovetop blew a fuse and it now will not turn on. The display says F1 and beeps. I unplugged the unit at the wall twice for 30 seconds, but it still is not working.
The fuse blew because your circuit board is defective. We have the correct control board for you to replace on this model.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service. We answer our customers calls from 7 AM until 9 PM CST, so give usa callwhen you are ready to repair this and we will get it out toy ou asap.
We would love to get you cooking again soon.
Thanks, Ella
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire range gives off a F1 signal for time to time. This began last week and continues peroidically when using the burners and or oven. Is this a problem with the sensor?
This is your electronic oven control that is going out on this unit. We are factory authorized Frigidaire service and parts suppliers and will happy to get the correct part out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service when you are ready to perform this repair and we can send you instructions on part removal and installation. You will save a lot of $$$$$$ by repairing this your self.
We look forward to hearing from you and we hope to get you up and cooking again soon.
Thanks, Ella
F1 fault code Frigidaire electric range
Hi, you stated that you cooked a meal that produced some humidity inside the oven. this is the cause of the F-1 code. the humid conditions that were present at the time, caused the EOC(electronic Oven Control) to short. you will need to replace this control board at this time. it has failed.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I have the F1 appeares at the front and ringing all the time
Sorry. Your electronic oven control (clock) is bad and must be replaced.
Before you do that you might try opening the control panel.
Unplug the range from power.
Unplug the connections to the control wait 30 seconds and re-attach.
If that does not work.
EOC time.
Mar 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
66 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Carew
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
