Polar Ft7 Mens Heart Rate Monitor Black with Red Display Logo
K
Kirk Posted on Sep 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the language setting? - Polar Ft7 Mens Heart Rate Monitor Black with Red Display
Mister Danger
Level 3:
  • Polar Master 5,631 Answers
  • Posted on Sep 26, 2015
Mister Danger
Polar Master
Level 3:
Answers
5631
Questions
0
Helped
1199168
Points
47629
Language settings should be specified in your user's manual.
See General Settings, Page 12-13
Read it. If you don't have one, download it from here
http://www.polar.com/e_manuals/FT7/Polar_FT7_user_manual_English/manual.pdf
See video
Polar FT 7 Heart Rate Watch review
Polar FT7 Heart Rate Monitor
Polar FT7 Fitness Heart Rate Monitor HeartRateMonitorsUSA com Polar FT7 Review 2015 Best Heart Rate Watch
How to change date and time for VISIO E320-B0
It should change by Time Zones and then Auto Update (Mode 321). It looks like your model was updated to the 321.. Perhaps you need a Firmware update, but my feeling is that it is a 21 year old television and it can't cope after Y2K and Time Server issues?
Changing The On-Screen Menu Language; Setting The Tv's ...
https://www.manualslib.com > ... > User manual
Vizio E321ME Manual Online: changing the on-screen menu language, Setting The Tv's Date And Time, Setting The Time Zone, Adjusting The Time For ...
Changing The On-Screen Menu Language; Setting The Time ...
Vizio E320-B0 Manual Online: changing the on-screen menu language, Setting The Time Zone. Your Tv Can Display The On-Screen Menu In Different ...
How to set time and date on my vizio tv model E320.B0 - Fixya
https://www.fixya.com > ... > Televison & Video > Vizio
Feb. 18, 2015 - how to set time and date on my vizio tv model E320.B0 - Vizio Televison & Video question.
E320-B0 - USER MANUAL
http://cdn.vizio.com > manuals > e320b0manual
PDF VIZIO. USER MANUAL. Model: E320-B0 ... And congratulations on your new VIZIO HDTV. ... it is left unattended or unused for long periods of time, unplug.
Jul 07, 2021 • The Watches
35helpful
2answers
Change language back to english on polar heart rate monitor ft4
I had the same problem. So I will try to guide you by button push method (because I didn't understand anything in Dutch that said on the panel). If you look at the polar main wrist watch (easy to say) you will see 5 button. 2 of left and 3 on right. 2 left are top -backlight (21) bottom - back or exit from menu (22). The 3 right buttons are top - scroll up (31), middle - menu (32) and bottom -scroll down (33). Now we know the button number here we go.
Hold 22 for 3 sec. You will see current time showing up. Press 33 once -- Setting ---> press 32 once ---> watch time and date ---> press 33 three time ----> general setting shows up ----> press 32 once ----> button sound shows up ---> press 33 twice ---> language shows up --->press 32 once ----> language blinks ----> press 33 or 31 till you see english or your language of choice ---->press 32 once ----> language is set ---->press 22 for 3 sec and you are back to the watch menu. Hope that helps. This will guide you even if you don't understand anything from the language.
My DZ4067 functions in the non-English day of the week for 21 hours a day now. How do I change it back so the the day of the week is in English for 21 hours a day?
The "day of the week" wheel on your watch actually has 2 settings on it--one for English, one for another language (often French, but could also be Russian, Japanese, Korean, or any other language, depending on the intended distribution of the watch). You'll need to shift the day track over by "half a notch," so to speak, to get things back in alignment.
The crown you use to set your watch can be pulled out into 2 positions. If you pull it all the way out, you set the time. If you pull it half-way out, you can set the day and date. If you turn the crown clockwise, you advance the date. If you turn the crown counter-clockwise, you should be able to change the day of the week. However, instead of turning the day back a full day, stop when you get a day with the correct language on it. At this point, pull the crown out all the way and manually advance the time 12 or 24 hours until the day and date advance as they would when the watch is running. This is to check that you've correctly gotten the day track correctly oriented. You may have to repeat this process a second time to get it right.
Once you have the day back on track, adjust the date and time, and you should be good to go.
Diesel's own directions, which can be found here: http://store.dieseltimeframes.com/common/images/customercare/instructions/ENGLISH/Diesel_Core-Inst_ENG.pdf are pretty cryptic, but they do have a diagram that might help a little bit. You'll want to look at the section for "Day/Date Watch IS02, 507.2-3, 517.2, 2105, 2305, 2405"
4helpful
Need to change language on day display from French to english.
1)Rotate crown fast - to change into "date + day" mode
2)crown up
3)fast rotation or the crown = changing the language (en, spain, france, german)
(when rotate crown slowly = you'll change year).
Or read full manual where this procedure are written in exact form:
http://www.tagheuer.com/_documents/manuals/EI2254_en.pdf
HOW SETTING LANGUAGE POLAR RS400
Under my tips and tricks page you can download the manual for the RS400.
The settings for language is under settings>general.
1helpful
I've charged up my Garmin forerunner 405 for the first time and it's stuck on the language setting page. I can scroll through the languages, but can't press enter to select the Language ("English")??...
It looks like you have so called cold push button. In fact there is nothing to do with push button as the fault is in contact or in microchip, but that's a long story to explain. You probably would be able to fix it with my help, but as I understand, your Garmin is brand new and still under the warranty, so, there is no reason to open it yourself and loose the warranty. My advise is to go back to the retailer who sold it and ask to change it for the new one.
Rate me, please.
3helpful
2answers
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
1helpful
Need the instruction manuel
Follow this link:
http://www.citizenwatch.com/COC/French/settings.asp
You can change language as well. This one is in French.
Rate me, please.
Top Polar Watches Experts
NOEL
NOEL
vince
Alex Kimuyu
Are you a Polar Watch Expert? Answer questions, earn points and help others
