Dishwashers Logo
Posted on Sep 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MODEL DWF31 DISHWASHER PROBLEM GOES THROUGH PROGRAMME UNTIL LAST DIGIT ON DISPLAY STICKS HAVE TO PRESS END PROGRAMME
Jim R
Level 2:
Scholar:
  • Expert 59 Answers
  • Posted on Oct 03, 2015
Jim R
Expert
Level 2:
Scholar:
Answers
59
Questions
0
Helped
30360
Points
193
Please see this important information
Hotpoint Dishwasher Safety Alert
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
2answers
Unlock ford car radio. have code.
can you give the number or name of the model
1helpful
Model ESL 499. Why doesn't it start?
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Dado
1helpful
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
AEG OKO FAVORITE 4070 - AFter not using for a week dishwasher is flashing dry & end together, will not switch off unless turn it off at the power point, there is no water left in the machine.
If the END or DRYING indicator on the programme progress display is flashing, you can probably rectify the fault yourself.
After rectifying an END or DRYING fault, press the button for the wash programme that has been started.
The wash programme continues. If the fault is displayed again, than check water leakage in the battom of dishwasher.
Malfunction: END and DRYING on the programme progress display are flashing simultaneously.
Possible causes: The leak prevention system has been triggered.
Remedy: Try to find and repair water leakage otherwise close the tap and call customer service.
Dado
1helpful
I have got a vreg corsa with a stereo that hasnt got a display.could u please tell how to put the code in because the numbers only go to 6 on the stereo and in the code there is a 9 and 7 please help the...
Find your Blaupunkt instructions on this free Code Entry website.
http://www.radio-code.co.uk/code-entry-help.php
The exact instructions will depend on the radio model.
If your display is NOT working and you have the CORRECT code then the usual method to enter the code "blind" is to ADD 1 to each digit.
So Code 1234   would be entered "blind" as 2345
A typical Blaupunkt with a separate display is the model CAR300
Below are the Code Entry Instructions for that model
(Don`t forget to ADD 1 if you are entering the code "blind".)
 INSTRUCTIONS TO ENTER A BLAUPUNKT CAR 300 (no display ) RADIO CODE
Switch the ignition key ON
Press and hold
AS button *  and the  ON button at the same time
Display Shows SAFE  then goes to 10 - - - - with a
"Beep" from the speaker
Press Preset Button "
1 "repeatedly until the 1st Digit of your Code is displayed
2" repeatedly until the 2nd Digit of your Code is displayed
3" repeatedly until the 3rd Digit of your code is displayed
4" repeatedly until the 4th Digit of your code is displayed
If the display  now shows the correct Code number then
Press  Button
AS  and hold to Enter and if successful  there should be a "Beep" from the speaker and the radio should switch on
2answers
Hotpoint Aquarius DWF31
to isolate fault,remove bottom front panel,turn off main water,put a tray under machine, remove inlet pipe frompump at front of machine. for a second to see if you have flow that far. If so trouble is in machine. Dig the filter out of th pump entry .It could be blocked
3helpful
2answers
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
1helpful
Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
