Question about Proscan 32LB30QD 32 in. LCD TV
I have already tried unplugging my tv and unplugging my cable. As far as I can tell the channels that are not working are E and NBC There is no SAP on my TV either. To show, what i think, is audio I use a button "MTS". When I push this it only displays "mono".
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Posted on Jan 28, 2009
SOURCE: Poor sound quality
Hi, I sent an email regarding the issue to OnCorpus (the company who makes ProScan)
This is what I got back:
Thomas,
Follow these steps to correct humming issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
[email protected]
I can't confirm if this works at this moment since I don't have access to my TV.
Thomas
Posted on Feb 24, 2009
SOURCE: PROSCAN 26" LCD TV with DVD won't show all the channels
bought 26 in pro scan tv can't figure out how to connect dvd player,craziest thing i've ever seen.please help
Posted on Mar 15, 2009
SOURCE: What connection do I use for audio out from my
It varies from one device to another, however the most common are RCA cables and optic fiber. You need to check which your device uses.
RCA
Fiber
Posted on Aug 24, 2009
SOURCE: what channel is the tv needed to be on to get
Most cable TV systems that use a set top box or converter output on channel 3 or channel 4.
If you have HD cable service however, you probably watch on one of the A/V or HDMI inputs (Video 1, Video 2, etc.). Simply press the Video or A/V input selector, slowly & repeatedly until a picture & sound is seen and heard.
Posted on Apr 01, 2011
Hi Anonymous, we want to help you with your question, but we need more information from you. Can you please add details in the comment box? What channel is it Racing channel 78 Australia DTV ? If it is this channel the cause of this channel with no audio is TV can't decode the MPEG used on channel 78 if TV is an older model .
