The date & time never stays set. there were no instructions with the camera so what does the designs on top of the dial mean this is where you set for close up etc but I don't know what the designs mean. THere is one red design Is that for red eye?
In order, starting with the "P"
P - Program - Access to more manual settings than Smart Capture mode.
"hand" - Blur Reduction - Reducing blur caused by camera shake or subject motion.
"VIDEO" - Capturing Video with sound
(red colored camera) - Smart Capture - General picture taking - it offers excellent image quality ad ease of use. The scene is analyzed for other content and for lighting. You can choose the best picture size and aspect tatio for your needs - just press the Menu button and choose picture size.
"Flower" - Close up - Use available light instead of flash, if possible.
"Sport" - Subjects that are in motion.
"SCN" - Scene - Point-and-shoot simplicity when taking pictures in practically any situation.
You can download the PDF file by Googling your camera make and model. I'll try adding it here with the link. You might have to copy and paste to your own browser.
Hope this helps. Mike
[PDF]
KODAK EASYSHARE CD82 Digital Camera
resources.kodak.com/support/pdf/en/manuals/urg01070/CD82_xUG_GLB...
KODAK EASYSHARE CD82 Digital Camera Extended user guide www.kodak.com For interactive tutorials: ... Use power-saving features (see Using the Setup tab, page 28).
SOURCE: Can't reset Date & Time
What you have to do is go to the icon with the spanner (as shown above) and keep tabbing down. There are more options than just the ones you see in the screen (not just High Power , Auto, Set Tag, On), keep going down and it will show you the other options. You will see the date change icon about 7 or 8 down.
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
SOURCE: how do i change the
Turn the Kodak's dial to "Capture" mode. This brings up the camera display. Press the "Program" button behind the dial. Press the "Down" button until "Date Stamp" is highlighted. Press the "OK" or "Set" button to access the date-stamp menu. Press the "Down" button to change the selection to "None." This removes the date stamp. Press "OK" to save the setting. Press "Program" to return to capture mode.
