Question about Saniflo Saniplus Macerating Pump
When Saniplus keep rumbling but did not pumping waist away what should I do A) switch off and call plumber or B)newer switch off
Posted by Anton Labenski on
3 Related Answers
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Posted on Jan 28, 2009
nivek1
  • 37 Answers
SOURCE: The pump on my saniplus will not switch off. I
Either the water cannot be pumped away due to a blockage in the pipe OR the membrane is covered in limescale and no longer operates as it should, try soaking it in a descaler and cold water for 24hrs but it may take 3-4 attempts.
Posted on Feb 26, 2010
Anonymous
  • 33 Answers
SOURCE: Our Saniplus pump runs for no apparent reason
if the pump operates then the pump is ok. if the pump switches on for "no reason", this indicates that the saniflo unit is filling slowly with water. as you have a saniplus, then you probably have a handbasin and bath / shower connected to it. If the taps / valves drip, or the wc cistern "leaks" into the bowl then these could be the sources.
Posted on May 10, 2010
I just had a brand new sanipro installed in a newly created ensuite, this is its ist week and the pipe keeps bursting out, called the plumber back and he refixed the white pipe to the wall,now it has burst...
Number one don't pay that plumber, number two get a new plumber as the last one has not a clue what he's doing. I would go through what I would do but not knowing what kind of a mess the last so called plumber left the pipe joint in it may make things worse. I know this is a pain in the A but you have no other alternative but to clean things up and wait for a new plumber. I hate when people that call themselves plumbers do this to people, it gives all us Plumbers a bad name.
Mar 20, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
The pump keeps running after flushing. Have to tap pump tank unit slightly to get it to shut off. Also from time of installation the water level in the bowl was and still is very low, any way to raise the...
hi keith
Bloues hear.
the water level in the boul is standerd to the manefactuer. the plumber cant help for that. if u put a level on ur toilet and iets level there is noting u can do about it.. the water that keeps on runing is ur seal rubber, its located at the bottem of ur flush meganusum. step 1.... tack off sistern aka pump. then step 2 ... unscrew your flush meganusem, will be the 1 in the middel of sistern. step 3 ... after unsrewing it u wil see there is a rubber. if the rubber looks fine then u must ajust ur flush meganisems arm or lubricate it. bt if rubber is misformed or teared ... u must go to a plumbing shop with the rubber. they will give u new 1 for cheap. and u can just reaplace it and esembel the sistern again
Jul 05, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
The pump on my saniplus will not switch off. I have to switch the power of on the wall.
Feb 16, 2010 | Saniflo & Saniplus& Macerator Pump
Saniplus pump runs and pumps a cup of water and
unlikely to be a vent problem - more likely a semi blocked 22mm outlet - hence the problem with the old unit & the new one. Tricky to solve as 22mm pipe runs are too small for conventional pipe cleaners. Some plumbers use compressed air to clear, others us pressured water (jetter) unfortunately it always ends up a bit messy.
Feb 13, 2010 | Saniflo 002/003/005 Saniplus Toilet with...
Our Saniplus pump runs for no apparent reason. Do I need a plumber, an electrician or a new unit?
Sep 14, 2009 | Saniflo & Saniplus& Macerator Pump
Jan 28, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Toilet pan installation procedure
Hi muller2012,
I'm Harvey the Master Plumber.
Your question is: the procedure to join pan to waste pipe without leaking. do i silicone around rubber seal?
In 30 years this is the first time I've heard of a toilet "pan". If you're refering to the bowl, it connects with a wax ring and a pair of bolts. You then caulk around where the bowl meets the floor to keep cleaning liquids from getting under and getting stinky. If this is not a standard toilet it would be a good idea to post pictures and give make and model.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Oct 14, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo Saniplus Macerating Pump Logo
458 people viewed this question
Top Saniflo Plumbing Experts
Bill Johnson
Vernon Taylor
Tom Chichester
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
