2013 Ford Focus Logo
A
Anonymous Posted on Sep 25, 2015
A piece of material from my golf trolley has got stuck in the lock - now unable to open Boot. Dashboard warning that Boot is open. Can you help, please?
fordexpert
Level 3:
  • Ford Master 5,692 Answers
  • Posted on Sep 26, 2015
fordexpert
Ford Master
Level 3:
Answers
5692
Questions
Helped
1975947
Points
17063
If your Focus has fold down rear seats you may be able to climb into the trunk and pull on the Emergency trunk release hanging inside the trunk,
1helpful
Ford Streetka convertible 2006
Central locking motor for the boot latch may be stuck open. If it also use cable type release, that lever may be stuck at release position.
1helpful
BOOT OPEN but not open warning light on dashboard say this with red warning light
The sensor is located and probably built into the boot latch. The sensor is good because the light goes off if you close it slowly. the latch is just worn out with that particular part. Replace the latch. It is not hard to replace if you have a few hand tools.
1helpful
Dashboard light showing door open when its closed on mk4 golf
The problem will be the 'door open sensor' switch. It is out of sight inside the door latch area. This video shows where it is.
http://www.youtube.com/watch?v=BB7o_9MPu4o
2helpful
The EPS light has come on my dashboard yesterday what does this mean and what do i need to do ?
The ESP system means the Electronic Stability Program. If the ESP lights on the dashboard permanently the ESP system is faulty. You must access the ESP Electronic Control Unit (ECU) memory for pull out all DTC (Diagnostic Trouble Codes), using diagnostic equipment connected to the data link connector of the car (placed in dashboard, under a plastic cover above the ashtray). Then you will be full informed about bad pieces (e.g.: front right wheel abs sensor interrupted, ...). After bad pieces replacement you will be able to erase all faults memored by ESP ECU, in other words reset the ESP system and turn off the warning lamp on dashboard.
Boot on vw golf mk4 wont open
have somebody pull up on the trunk while you press the button inside
2answers
My golf mk4 tdi boot wont open atall
Get hold of a can of Plus Gas or even WD40
Open the slot where the key goes into with a thin screw driver push the thin tube on the can then into the hole
Cover with a piece of tissue , give it a god blast and leave it for a few hours
Do it again and this time gently rock the key as if you are trying to opem the boot
It should free off
As they say if you dont use it you lose it !
How do you remove boot lock on vw passat 1999 1.8SE
Unable to open the boot on my 1999 vw passatt either by the remote or using the key. How can I open the boot from the inside?
1helpful
Need help
There is a release in the boot (trunk).  It's a little green piece of the plastic about 12mm diameter that is stuck in the trunk lining just on the other side of the fuel filler.  Pry it out of the liner and pull on it.  That should open the fuel door.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
