Question about Garden
Do you have or can you find Agrator Rototiller Gears ?
If so can you call Dorlin Drader 503-435-8088
Posted by Jodi Coulston on
Claude Kayser
    Top Expert:
  • 9,098 Answers
Agristore USA ' Replacement Parts ' Agrator Tiller Blades
www.agristoreusa.com/collections/agrator-tiller-blades
Tiller Blade for AGRATOR D-UR $6.75 · Tiller Blade for AGRATOR D-UR $6.75 · TillerBlade for AGRATOR D-UR $8.50 · Tiller Blade for AGRATOR D-UR $8.50.
Posted on Sep 25, 2015
Rototiller was slipping out of gear when tilling now it sounds rouff but wheels turn tines turn if not on the ground
check for a failed shear pin on the drive shaft or broken teeth on the drive gears
Apr 16, 2017 | Garden
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
MY ROTOTILLER RUNS AND DRIVES BUT THE TINES WONT TURN
Make sure that the clutch doges as I call them are engaging properly. Also check rear tine gearbox for striped gears or sheared keys. To check some of these things it may be necessary to remove rear tine gearbox by removing the 4 bolts that hold it on to the main transmission. Hope this helps.
Sep 17, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Rototiller wonts change gears
Try rocking the wheel as you try to shift.
Apr 30, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
Sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Aug 20, 2009 | Craftsman Garden
We require help with a broken belt on the rototiller
bring the broken belt to napa auto parts or kragen ,,or go to www.managemyhome.com they can tell you where to buy or get it
May 20, 2009 | Garden
Rototiller transmission
I am having transmission problem (loud noises). I am looking for a repair manuel for a roper rear tine tiller. Model RT150GR chain drive.
Mar 27, 2009 | Craftsman Garden
Garden Logo
308 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
