Jaguar Sensor, XJ6, XJ8, XJS, XK8, S-TYPE, X-TYPE, XJ40 ...
www.jagbits.com/jaguarsensor.php
FITS: 1993-1994 6.0 XJ12 AND 1989-1993 V12 XJS FROM VIN 157118 ON, 1994-1996 6.0 V12 XJS FRONT DAMPER .... LNA1622AA - MAP SENSOR ... C42166-USED - USED SENSOR COOLANT TEMPERATURE FOR FUEL INJECTION
Get the
coolant pressure tested, its definitely leaking coolant. You will need to get
the coolant running line.
Pressure
test will help you to know from where exactly coolant/refrigerant is getting
leaked.
For complete
step by step troubleshooting i suggest you to go through the help links
mentioned below :----
Click the
link below :-----
Coolant enters in transmission on Toyota Land cruiser?
http://schematicsdiagram.blogspot.com/2012/01/coolant-enters-in-transmission-on.html
1991 Toyota
Camry: Order Coolant Bypass Tube?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-camry-order-coolant-bypass.html
2002 Toyota
Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
1994 Toyota
Camry: Coolant Leak?
http://technoanswers.blogspot.in/2012/04/1994-toyota-camry-coolant-leak.html
2006 Cadillac DTS: COOLANT LEAK AT DRIVER SIDE NEAR
FIREWALL?
http://schematicsdiagram.blogspot.in/2012/04/2006-cadillac-dts-coolant-leak-at.html
MAF, IAT, MAP and Coolant Level Sensor problem all together
on Mazda MPV?
http://schematicsdiagram.blogspot.com/2011/12/maf-iat-map-and-coolant-level-sensor.html
GMC Engine Coolant Temperature (ECT) Sensor Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-engine-coolant-temperature-ect.html
Loosing Coolant?
http://whoisbyme.blogspot.in/2012/06/loosing-coolant.html
Coolant temperature sensor dies again and again?
http://schematicsdiagram.blogspot.com/2012/01/coolant-temperature-sensor-dies-again.html
2000 Daewoo Lanos: Where to Add Coolant?
http://repairhelpcenter.blogspot.in/2012/06/2000-daewoo-lanos-where-to-add-coolant.html
Blue Water Warning Light on Dash?
http://whatisbyme.blogspot.in/2012/07/blue-water-warning-light-on-dash.html
Replacing
Oldsmobile Engine coolant sensor?
How
to test Engine coolant temperature sensor?
Replace
Coolant Sensor Module on Oldsmobile?
These details will help.
Thanks.
