Electrical Supplies Logo
A
Anonymous Posted on Sep 25, 2015
Homelite HG600 Lightnin'bug generator. Where can I get an owner's manual?
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Sep 25, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067246
Points
28436
Homelite Vintage Camping Generator - HG600 Lightnin Bug ...
? 1:23
www.youtube.com/watch?v=Amq5VLOsiN8
May 6, 2014 - Uploaded by david lum
For Sale: Great Generator 500 watts - quiet - looks like new - starts easily. Complete with owners manual.
How do I drain oil on a Homelite HG600 Generator?
Correct, tip the engine to the side that has the fuel cap/intake or if its on other side tip on that side etc
Whilst tipping slowly pull the starter cable to turn the engine.
Hope that helps
4500 running watts 5625 starting watts
http://www.manualowl.com/p/Homelite/HGCA4500/Manual/185973
1helpful
Battery charging and control, electric start. Need schematic and parts list.
The UT number for this generator is UT-03559. The problem is like yours can't find anything online in the line parts or owners manuals for this unit. You may try http://www.ktoutdoor.com/
They were listing this number. doesn't mean they have anything on it but might be worth a try.
Here is alternate idea on recharging the battery use a 12 dc ac adapter for recharging while the unit is in use.
I have a hg 6000 homelite generator, runs great but does not give me any power. i used it a year or so ago an everything worked fine. got a lil smoke from where windings are. the generator was made in...
Hi and welcime to FixYa. I am Kelly
This is going to sound odd but.... this is how it it is recommended to field flash and inverter type generator. (Brushless) The steps are to (not kidding...) use a male mail interconnecting wire from your house wiring and plug in your generator and turn ON the main CB for 1 minute.
If this does not work.... See steps below amnual links.
Owners manual link: (Click on get manual)
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/hg6000_1.html
Or try this direct link:
http://lawnandgarden.manualsonline.com/support/homelite/portable-generator/request-manual-299128
This is a brushless generator... Not sure what the smoke was but... the yellow wires are for the capacitor winding. If you probe the capacitor terminals with one of the wires disconnected with a meter on R x 10,000 you should see a brief jump in resistance and then the meter drifts to infinity.
reverse the test leads and test again looking for the same result.
Next read resistance Yellow wire to Yellow Wire (Stator capacitor loop check) It should read low resistance
Also read Brown wire to Brown wire. This is the DC stator loop check. Is should read resistance.
Main winding checks Red to Blue and White to Brown that goes to the main breaker. OR Turn the Main breaker on.. White to lower left pin of 30A 4 pin output recepticle. Bot red to blue and White to Brown MUST read low resistance
These are all the checks except the rectifier and the rotor. You will probably find something during the above tests. If not... respond here and I will pass on the rotor and diode tests.
Kelly
I need a wiring diagram for a homelite HRI4400HD generator please.
Go to Homelite's web page http://www.homelite.com/ and you enter your Model Number and download the Owner's Manual, that should have wiring diagram in it. If you don't find it. contact Homelite Customer Service.
Hope this helps you find what you need.
23helpful
Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Homelite Lightnin Bug Generator not getting gas
try leaving your choke partially on it may not be getting all the gas it needs,see if it will run then, it wont run full throttle, but this will tell you its not getting enough gas
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
