Question about Daewoo Vcr Player Video Player Recorder Vcr Vhs 4 Head
How do you clean the DVD Video?
Will not load disc, says 'no disc', makes alot of noise like it is trying to read but cant.
Ivars Vitins
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 29 Answers
Http://www.wikihow.com/Clean-a-DVD
Posted on Sep 25, 2015
Testimonial: "Thank you for your response which helped me realize I asked the wrong question."
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
When i put in a dvd, it makes clicking noises, after that a notice
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 14, 2012 | Sony Televison & Video
Audiovox D1998 Portable DVD Player will not load DVD
you need to clean the disc and make sure it fits in wright if that dose not work try another disc.
Sep 15, 2009 | Audiovox D1917
Its making a clicking noise and not reading the disc
disc drive is knacked, some times the laser gets dirty and cant read so it will keep skipping back and forth so try a disc clean first
Sep 12, 2009 | Microsoft Xbox 360 Console
It cant read a dvd "no disc"
Check and make sure the laser eye is clean and clear of dust and smudges. With player OFF, blow across laser eye. Try cleaning with soft dry Qtip. Otherwise you probably have a bad laser drive or bad drive ribbon cable.
Dec 28, 2008 | Durabrand PDV-705 Portable DVD Player
SONY DAV DZ260, home theatre. Trouble reading the disc.
There is some intermittent connection that is causing the issue. Finding it might prove to be a bear - I would recommend sending it back for another working.unit.
Jun 25, 2017 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Noisy wii console
Hi Sky606, have you tried cleaning the game disk? Have you tried using other game disks in the wii to make sure it's not just one disk that is causing the problem. Do you have a Nintendo Wii CD / DVD Discs and Lens Auto Cleaning System ? If you don't you might want to purchase one and see if that helps, because your wii lens might need cleaning ! If all of that fails,your wii may need repairs, the lens that reads the CD/DVD could need adjustment or replacement ! One other small note,I always have a small external fan blowing on my wii when in use so that the wii wont over heat. Heat kills electronics ! I Hope this advice helps.
Jun 06, 2008 | Nintendo Wii Console
TV doesn't read movies .makes weired noises
hi try cleaning your DVD player because theres an eye that reads the disc so if you try to clean your DVD player if its not that then i cant help you
Jan 29, 2008 | Emerson EWC13D4 13 in. TV/DVD Combo
PS2 Clicking Noise Read Disc Error
I had the same problem and I found a link that helped me, so try it! But make certain that you really want this thing fixed, because if you send it out they will probably do the same, may cost you alot more. Here all you need is patience, a litte time, and a clean area to work in! Here is the link good Luck:http://www.bolthole.com/ffxi/dvdclean.html It worked for me! I have no problems now!
Nov 26, 2007 | Sony PlayStation 2 (PS2) Console
My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Mar 20, 2006 | Panasonic DVD-S31S DVD Player
Daewoo Vcr Player Video Player Recorder Vcr Vhs 4 Head Logo
Top Daewoo Computers & Internet Experts
k24674
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
