I copied and pasted this answer from your other question as I thought it was the same one Sherry.... Hope it helps you.
It should automatically restart.....BUT what happened is that when you unplugged it, you cut off the blower at the same time you cut off the heat element(s). The way it is supposed to work, is the thermostat cuts power off to the elements and the fan continus to run for a per-determined amount of time to remove al the heat from the elements. Then another 'fan control switch' shuts off the fan once the 'residual' heat is removed from the heater. Without that 'cool down' cycle, the hot element had enough 'residual' heat in it to trip off the 'thermal overload' in the circuit. The 'thermal overload'... or...'hi limit'...or...'hi temperature control' is resposible for shutting power off to the element(s) in the event that the blower fails.
does your temp gage seem off does it go like up to the h because if it does you could try unpluging your upper coolent sensor because that could cause that because it is telling you computer to run in closed loop when it should be running in open loop
sorry to tell you but you have a blown headgasket or cracked cylinder head. that is why the coolant blows out of the radiator and the engine won't start due to engine compression getting into the cooling system.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
ensure that the projector goes through the cool down cycle, for example the fans stop running, before you unplug it. Unplugging it will cause it to into power failure mode which will not allow the lamp to turn on until the bulb reaches ambient temperature. it will also extend the life of that very expensive bulb. take the extra time to let it shut down before you unplug it.
This is a prtty uncommon problem. You should have the spark and fuel pressure checked when the engine will not start to see what system is shutting down. Sometime fuel pumps that are failing can shut down and then not allow the engine to restart until it cools down. By checking the spark, and fuel pressure this will tell you which way to go to try to figure out why it wont start after dying.
This error message means that the bread-maker is too hot. This machine has a cut-off switch and won't start until it cools down sufficiently. Wait a while, then try restarting.
