SOURCE: i want to clear the old code on my Weiser lock and
Here's a free manual you can print out with complete installation and programming instructions you can keep for addressing any other concerns you might have in the future.
I thought this might be easier for you to work from, since you want to reset the lock prior to entering in your new master code and any other access codes you wish to let others use.
It is easy and straight forward to program and use.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful - Best regards!
SOURCE: The original code will not clear from my Weiser
First, I fix this problem after an hour of try.
I
conclude that this dorr lock is better that is appear. Is not a 2 codes
door lock, it's a 3 codes one.. and the problem you have is the third
code not reset. You can put the same code in each third emplacement. you
have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
SOURCE: Deleting Codes on a Weiser powerbolt.
The Weiser brand and Kwikset brand Powerbolt are identical (Black &
Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice
that the above is a .PDF file type. That means that you need to have
Adobe Reader or similar installed on your computer to view it. So if you
are unable to view the file, download (for free) and install Adobe
Reader first. You can get it here:
http://get.adobe.com/reader/
SOURCE: I installed a weiser smartcode lockset and the
2 important things which may seem dumb but solved my problem:
- Make sure that once everything is in place, you hold the lock button before inserting battery pack (and keep holding the lock button) until you hear 2 beeps. The latch should come and go.
- Last but not least, make sure you put NEW batteries in... I had old batteries and when i tried it seemed like is was working but could not finish the door direction finding sequence stated above. Make sure they are new and it should work!
