Comcast XFINITY Logo
T
TomDowney Posted on Sep 24, 2015
Problem W/G.E.tv; Xfinity remote. Will not work. Cannot change channels or volume with the remote.
Xfinity remote will not work on my tv. neither will any universal remote
1 Related Answer
edoco
Ed PeeBee
  • 42 Answers
  • Posted on Jan 14, 2015
SOURCE: install netflix
Typically when you use Netflix for the first time it requires you to link your device by entering a code provided by the Netflix website. Perhaps exchanging the modem has made it necessary to "re-link" your device? If this is the case, log-on to Netflix's site and click on "Your Account & Help" on the Netflix website and click the link titled "Manage Netflix Ready Devices and Computers" from the "Watching Instantly on Your TV or Computer". You can then link the device pick-up where you left off! :)
How do I link LG AKB73615337 Remote Control to my xfinity flex box?
The LG AKB73615337 remote control is designed specifically for LG TVs and may not be compatible with the Xfinity Flex box. However, you can try the following steps to see if it works:
  1. Ensure compatibility: Confirm that the LG remote control is compatible with the Xfinity Flex box by checking the list of supported devices in the remote control's user manual or by contacting LG customer support.
  2. Power on the Flex box: Make sure your Xfinity Flex box is powered on and connected to your TV.
  3. Activate pairing mode: Put the LG remote control into pairing mode by simultaneously pressing and holding the "Back" and "Home" buttons for a few seconds until the LED light on the remote starts blinking.
  4. Follow the Xfinity Flex box pairing instructions: Refer to the Xfinity Flex box's user manual or contact Xfinity customer support to find the specific instructions for pairing a remote control. This process may involve entering a pairing code or following a series of steps on the TV screen.
  5. Test the remote control: Once the pairing process is complete, test the LG remote control to see if it works with the Xfinity Flex box. Try navigating the menu, changing channels, adjusting volume, and performing other functions to ensure proper functionality.
If the LG remote control does not work with the Xfinity Flex box or if the pairing process is unsuccessful, it is recommended to use the original remote control that came with the Flex box or consider purchasing a universal remote control that is compatible with the Xfinity Flex box. Universal remote controls are designed to work with multiple devices and usually come with instructions for programming them to work with specific devices.
Remember to consult the user manuals of both the LG remote control and the Xfinity Flex box for specific instructions and contact customer support if you encounter any difficulties during the pairing process.
2answers
Channel 1 will not mute when button is pressed. all other channels are fine
press it hard and try to vibrate the button sometimes it makes bad contact or random connection. Also try different remote or ask you cable provide for replacement.
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
How do I program a Toshiba remote to a zenith converter box
Signal converter boxes are pretty easy to set up - ABC News
abcnews.go.com/Technology/AheadoftheCurve/story?id=5485537
Digital Switch: How to Set Up Your Converter Box. ... If you subscribe to cable, satellite or some other pay-TV service, you'll continue to receive programming. ... aToshiba TV in my kitchen: Magnavox's TB100MW9 and Zenith's DTT901. The boxes are simple enough to set up, though I prefer the Zenith's remote control and ...
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!
Zenith remote control code list - channel recovery morning ...
www.thompsontv.com/zcodes.html
4answers
I need a comcast remote tv code for a AMP'D tv
For the comcast xfinity remote use the philips code 11454 from the lcd tv section. That is the code that I got to work
Top Comcast Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Are you a Comcast Televison and Video Expert? Answer questions, earn points and help others
