Toshiba Satellite A105-S4004 Notebook Logo
Question about Toshiba Satellite A105-S4004 Notebook
There is a bios password on my laptop and i forgot it how can i get pass that so i can factory reset it
Posted by Chetney Clark on
I bought a windows xp home ed laptop the ppl I bought it from forgot the password I caint get pass boot password what shouls I do?
To get past a boot password you will need to reset the bios. On your motherboard, inside the case there is a little battery. You will need to remove that for 5 minutes and then reinsert. This will reset the Bios to factory settings, removing the password and any other changes. Have a great day.
1helpful
2answers
[10140] SISTEM DISABLED MY LAPTOP PROBLEM IS WHEN I TRY TO ENTER THE BIOS PASS I FORGOT THE PASS IT SHOW THAT EROR
It is nearly impossible to reset the BIOS password without tinkering with the motherboard itself. You will need to contact the laptop manufacturer and have them reset it for you. If the manufacturer cannot help you, and you really want to risk it, you can unplug and open your laptop and remove the button-cell battery attached to the motherboard for at least 10 minutes. This will usually reset the BIOS settings, including the password.
I WANT TO RESET THE BIOS PASSWORD BECAUSE I FORGOT ON WHAT I NOTE IT LONG TIME AGO
Try entering the bios, in some bios you can reset the pass. The other way is to open the laptop, remove the small battery or use the jumper for resseting the bios.
Stelios.
4answers
Forgotten password for acer lap top
the password is for windows or for bios and if for windows any virsion of windows you use
Bios pass word
You can clear bios with factory defaults reset.
For that open back cover of your laptop.
Then pull cmos cell from motherbord for 10 minutes so all bios settings are defaults.
Then put again cmos cell in it's position then it not ask password.
Let me know if you need more assistanse.
Thanks.
2answers
I forgot the security password
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user password
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
1helpful
Need help forgot password for HP Compaq NX7330
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
Please rate me .
Thanks .
2helpful
Compaq Evo N800c BIOS PASSWORD LOST
the only way is to open the laptop up and there will be a small watch type battery, quite big but flat. it will be on the motherboard. take the battery off the otherboard for at least 10 seconds and then put it back in. this should reset the bios to factory default.
Forgot bios password
You might have to remove battery cell which is located backside of every laptop and then on your laptop try to access bios if it works then off the laptop attach the cell again in same position and enjoy bios without password.
jrpitale.
2answers
I HAVE A PC LIKE GIFT BUT ASK ME FOR A PASSWORD AND THE PERSON THAT GIME ME THE PC SHE FORGOT THE PASS WAHT CAN I DO
Remove battery for a few minutes and re insert.This sets it back to factory settings. Just reset time and date in the bios and you should be away.
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Top Toshiba Computers & Internet Experts
David Shaub
Steve Sweetleaf
Steve Sweetleaf
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
