The brew unit won't go back N is lined up correctly but the cog inside is not lined up to except brew unit, I've turned machine on and off but cog still out of sink.. Any ideas.
Machine is probably not in the fully "at rest" position. See if you can get the tray in without any other parts on it. Sometimes the waste grounds bin will foul on the mechanism if brewing unit has not stopped in the correct position. Once the bare tray is in and activating the switch the machine will realign itself when turned on.
Hi Ross I did what you said but cog in machine still not rotating to line up any more help please
Sorry Chrissy, out of ideas that don't involve pulling the machine apart. I'm conversant with Krups coffeemakers and was just trying to help with what works for them. If you can find a local Gaggia service agent and ask them they will be the most likely folks to have the answers. The machine is to complicated and expensive to be messing about with at home.
hey chrissy
did you solve the issue back then? )
having the same trouble right now
so to reposition internal mechanism I've done this:
- turn machine on
- press for around 2 seconds button for coffee and steam dispensing button -> machine repositioned itself and I could finally insert the brewing unit back in
Hello, i got the same issue with caffeo passione. I was cleaning the brewing unit and i can t fit it back i will upload photos witch two prts can t fit. I hope that someone can help me.
