SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: no arc for craftsman professional wire feed welder
either your not grounded on the vehicle very good or you lost the ground either in your gun or on your clamp
SOURCE: i have a speedline 180 amp arc welder and it
Check for output voltage (ac or DC depending on model).No voltage,welder has a problem.
You must have a clean ground clamp attached to bare metal with some welders to make them work.
SOURCE: solar welder 2175 wire keeps feeding wont stop
Look on the front pannel. thier should be a "latching Switch" indicated by "4 X 2" little arrowes. The 4 is " pull the triger -- the release the arc continues, the "2" is pull the trigger and the arc startes release the trigger the arc stops simplesssssssss
Ken
SOURCE: mastercraft arc welder
i have a mastercraft welder wire feed , the power turns on the wire feed works and the fan in side turns on but it will not weld not even a spark! can anyone help?
