Electronics - Others Logo
M
Michael Selby Posted on Sep 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How many battiers does my JF 32184 have. And what are they
Larry
Level 3:
  • Master 5,042 Answers
  • Posted on Nov 01, 2021
Larry
Master
Level 3:
Answers
5042
Questions
Helped
1240238
Points
18413
Take it apart and find out
06 Mercury Mariner po351, 352, 353, 354
What engine does it have? V-6 - V8
Looks like one bank of cylinders are dead.
P0351 - Ignition Coil A Primary/Secondary Circuit Description: See the description for DTC P0350. Possible Causes: See the possible causes for DTC P0350. Diagnostic Aids: See the diagnostic aids for DTC P0350. Application Key On Engine Off Key On Engine Running Continuous Memory Coil-on-plug (COP) ignition testing - GO to Pinpoint Test JF . GO to Pinpoint Test JF . Coil pack ignition testing - GO to Pinpoint Test JE . GO to Pinpoint Test JE .
P0352 - Ignition Coil B Primary/Secondary Circuit Description: See the description for DTC P0350. Possible Causes: See the possible causes for DTC P0350. Diagnostic Aids: See the diagnostic aids for DTC P0350. Application Key On Engine Off Key On Engine Running Continuous Memory Coil-on-plug (COP) ignition testing - GO to Pinpoint Test JF . GO to Pinpoint Test JF . Coil pack ignition testing - GO to Pinpoint Test JE . GO to Pinpoint Test JE .
P0353 - Ignition Coil C Primary/Secondary Circuit Description: See the description for DTC P0350. Possible Causes: See the possible causes for DTC P0350. Diagnostic Aids: See the diagnostic aids for DTC P0350. Application Key On Engine Off Key On Engine Running Continuous Memory Coil-on-plug (COP) ignition testing - GO to Pinpoint Test JF . GO to Pinpoint Test JF . Coil pack ignition testing - GO to Pinpoint Test JE . GO to Pinpoint Test JE .
P0354 - Ignition Coil D Primary/Secondary Circuit Description: See the description for DTC P0350. Possible Causes: See the possible causes for DTC P0350. Diagnostic Aids: See the diagnostic aids for DTC P0350. Application Key On Engine Off Key On Engine Running Continuous Memory Coil-on-plug (COP) ignition testing - GO to Pinpoint Test JF . GO to Pinpoint Test JF . Coil pack ignition testing - GO to Pinpoint Test JE . GO to Pinpoint Test JE .
TE 8000F. How can I reset my tills?
Press JF button while the key is on off . Now turn your key down to PGM while you are still pressing JF. then after releasing JF press sub/total
Powersteering out changed battier and fuse
IT is full electric no oil i change one one time
My 2002 yamaha r1 wants to start byself when i connect battier
there is a short circut, check the terminals at the solinoid
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_00678fd4800d19c5
Hi! My Toyota Matrix 2008 needs maintenance
there is no warranty for maintenance. at 30k the car is not recommended for much.ti should have longlife coolantand trans fluid.spark plugs should be 100k plugs.
Motorola c51
Hello mdellarusso. Disconnect the power to your phonebase. Remove the battiers from the portables. If the battiers are over 2years old replace them. Wait for 10minutes. Reconnect the base AC power, reinsert battiers and place on their chargers. Perform an operational test. If test fails I suggest a replacement system. Good Luck.
1helpful
CHANGE TAX %+ & TAX- ON MY CASIO JF-100TE CALCULATOR
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
3answers
Casio jf-120er euro rate set
Press AS
Hold Down RATE SET (%) for about 2 second and the correnty rate appears on the display
Imput the conversion rate and the press rate set (%) to store it in memory.
Best regards
Alberto
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
