Question about Samsung Televison & Video
Samsung LCD TV diagnosis. Possible tcon board?
Mod #LN46A55OP3FXZA. On start up picture normal. After 10 sec Green hue takes over certain gray scale colors. This happens on whole screen while there is something on the screen. When screen is empty (Stand by) normally there is a black back with blue "pop ups" with "check signal cable" and input details (HDMI 1). Screen is now a dark green. Center "popup" is normal. Upper left pop up has black strip on top (normal) and the rest is the same green with the boarder still visible. When in menu back is black (normal), menu list (normal) selector is dark green. When in TV input mode (coax) "static" no signal is normal white,gray, black pixels (normal) but pop up stating no signal (normally just blue) is blue but with red horizontal lines running thru the top few inches of pop up. Only in pop up. While watching TV all colors are present and normal other than the green that appears to only effect certain black/gray color scales. I am thinking Tcon. Can you confirm or point me in the right/better direction or possible remedies. Thanks
Posted by Brian Farmer on
Lawrence Oravetz
  • Samsung Master
  • 10,548 Answers
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Feb 10, 2016
5 Related Answers
Anonymous
SOURCE: Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Posted on Jun 15, 2009
Chi Chu
  • 8457 Answers
SOURCE: Westinghouse 32 inch lcd hdtv model # VR3209DF. screen problems
Ur tv the Tuner board,that where the coalax broscast signal cable come in to this board.This board is starting to have problems.
Posted on Jun 07, 2010
SOURCE: 46 inch Sony flat panel lcd has vertical red and
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Posted on Oct 16, 2010
John Cunningham
  • 6771 Answers
SOURCE: LCD TV no pic but sound, do have all screen glow..
What is the Samsung Model number so I can do a cross match of the Tcon board?
Posted on Jan 29, 2011
Azrael SRL
  • 11800 Answers
SOURCE: my 50 inch vizio plasma
Since the lines are vertical, the image is lost sideways and the corruption changes with the image then clearly this is a sign of Y-Sus failure, not the Z-Sus or the buffer boards.
An logic or input board failure would affect the entire screen, not just a part of it and a failure in one of the buffer boards would affect strictly defined lines of pixels and the defect would be constantly there all the time.
Since you haven't told us the exact model i can't point you to a replacement board.
Posted on Aug 06, 2011
Need advice on color issue with Samsung UN46EH6000F TV
The TCON board or the LCD panel is Faulty , Can confirm by replacing TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 04, 2017 | Samsung UN46EH6000FXZA 46 1080p 240Hz LED...
Samsung LED UA40F6400 suddenly lost picture.
The tcon board or the LCD panel is faulty. You have to replace the TCON board to confim the fault.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 06, 2016 | Samsung 40 Inch UA40F6400 Full HD 3D Smart...
How do I repair the color on my Samsung LCD TV. I can still see the picture but 3/4 of the TV goes green/purple/pink and the bottom 1/4 has normal color.
The T con Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
May 28, 2016 | Samsung Televison & Video
My tv model# 37lg50-ua. I have a dim picture black and gray
The TCON board or the LCD panel is faulty. You have to replace the TCON board to confirm. In some models TCON boards are integrated to the LCD panel if so you have to go for a new LCD panel.
May 24, 2016 | Televison & Video
Why does the screen turn white after 10 minutes?
Probably the t con board have problem. the power regulator ic on the tcon board make this problem. As ist an smd ic you have to go for a new tcon board, because its not possible to replace the ic with normal soldering irons. you need smd rework station for that purpose. And also on more thing in some tvs the t con board is integrated to the lcd panel. if so its not possible to replace only the t con board , you have go for a fresh lcd panel. it would be a costly repair. because the panel is the costliest part of the tv. Any why check the video to understand which one is the t con board. if you find one in yours then try to replace it with new one. hope your problem will solved
www.electro-medical.blogspot.com
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Nov 03, 2015 | Samsung Televison & Video
I have a samsung lcd tv that powers on has sound but the picture is fuzzy and has no colour . What would be the component that needs replacing for this ??
Hello. Before you start replacing parts, make sure your connections are correct. It sounds like you have connected a composite source to a component input. Composite is three RCA plugs, a yellow for all of the video, and a red and white for audio left and right channels. Component is five RCA cables, green, red and blue for video, and red and white for audio. if composite is connected to a component input, the picture will be black and white with squiggly lines all through it.
Mar 31, 2015 | Samsung LN40A550 LCD TV
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
Jul 03, 2017 | Samsung LE37R72B 37 in. HD-Ready LCD...
My LG HD tv screen has a wide, gray band on either side of the picture
Try changing 'perspective' or screen ratio.
This may work, but could also stretch the picture too wide,
On my non-LG TV this is called 'aspect ratio' under the 'picture' menu.
Nov 20, 2017 | LG 42LB1DRA 42 in. LCD Television
We are having SAMSUNG LA37R81B tv at home its showin blurred picture we asked repair man he said we need the tcon board number so that we can buy we now need your help
it possible that the problem is the the TCON board, you can try websites Shopjimmy.com,Ebay.com to buy a refurbish board for the replacement.
Also note that
The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
Hope this helpout..
Jul 30, 2010 | Samsung Televison & Video
Televison & Video Logo
273 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
