BT Synergy 6500 Cordless Phone - DECT - Silver Titanium 1 x Phone Line - Answering Machine - Caller ID - Speakerphone - Backlight Logo
B
Brenda Hogan Posted on Sep 21, 2015
How do i open battery compartment - BT Synergy 6500 Cordless Phone - DECT - Silver Titanium 1 x Phone Line - Answering Machine - Caller ID - Speakerphone - Backlight
Where is the battery door for pstsl21p52?
Replacing the Batteries
  • Open front cover and locate the battery compartment door.
  • Gently remove the two "AA" alkaline batteries located in the battery compartment.
  • Install two new "AA" alkaline batteries into battery compartment. Make sure to match the positive (+) ends of the batteries with the positive (+) terminals located in the battery compartment.
  • Close battery compartment. The low battery indicator should not appear in the display.
Feb 24, 2024 • Cameras
DM75Royal personal Organizer
If you need to replace the batteries in your DM75 Royal personal organizer, here are general steps you can follow. Keep in mind that the specific process may vary slightly depending on the model:
1. **Locate the Battery Compartment:**
Look for the battery compartment on the back or bottom of your DM75 Royal personal organizer. The compartment is typically secured with a screw or latch.
2. **Open the Battery Compartment:**
Use a small screwdriver or coin to open the compartment. If there is a screw, turn it counterclockwise to release it. If it's a latch, slide or press it to open the compartment.
3. **Remove Old Batteries:**
Take note of the orientation of the old batteries (positive and negative terminals). Remove the old batteries from the compartment.
4. **Insert New Batteries:**
Insert the new batteries, making sure to align them correctly with the positive and negative markings inside the compartment. Follow the same orientation as the old batteries.
5. **Close the Battery Compartment:**
If there was a screw, secure it back in place by turning it clockwise. If it was a latch, close the compartment securely.
6. **Test the Personal Organizer:**
Turn on your DM75 Royal personal organizer and check if it powers up. Ensure that the display is functioning correctly.
7. **Set Date and Time (if necessary):**
If your personal organizer has a clock function, you may need to set the date and time after replacing the batteries.
Please note that the above steps are general instructions, and the design of battery compartments can vary between models. If you encounter any difficulties or if your specific model has unique features, it's advisable to refer to the user manual that came with your DM75 Royal personal organizer. The manual should provide detailed instructions on battery replacement and other essential functions.
If you don't have the user manual, you can often find it on the manufacturer's website or contact Royal customer support for assistance.
How to replace the battery
To replace the battery on a remote, you will typically need to remove the back cover of the remote to access the battery compartment. Here are the general steps you can follow to replace the battery on a remote:
  1. Locate the battery compartment: The battery compartment is usually located on the back of the remote and is typically held in place by a small latch or a screw.
  2. Open the battery compartment: Depending on the design of the remote, you may need to use a small flathead screwdriver or a coin to open the battery compartment. Some remotes have a latch that you can slide to open the compartment, while others have a small screw that you will need to remove.
  3. Remove the old battery: Once the battery compartment is open, you can remove the old battery by gently prying it out of the compartment using a small flathead screwdriver or a similar tool.
  4. Install the new battery: Insert the new battery into the battery compartment, making sure that the positive and negative terminals are oriented correctly. The positive terminal is usually marked with a + symbol and the negative terminal is usually marked with a - symbol.
  5. Close the battery compartment: Once the new battery is installed, close the battery compartment and secure it in place using the latch or screw.
If you are having difficulty removing the back cover of the remote or are unsure about how to properly install the new battery, you may want to refer to the owner's manual for your specific remote or contact the manufacturer for assistance.
I just change the batteries on my Bestech thermostat now it reads -d??
1.Open front cover and locate the battery compartment door.
2.Gently remove the two "AA" alkaline batteries located in the battery compartment.
3.Install two new "AA" alkaline batteries into battery compartment. Make sure to
4.Close battery compartment. The low battery indicator should not appear n the display
Open battery compartment
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
1helpful
Cannot open battery compartment on Sony Cybershot rmt-dsc1 remote
@ Frans Bedford-Visser
On the right side of the battery compartment you can see some vertical plastic lines. Pull those towards the compartment. Simultaneously open the compartment as indicated by the arrow. It will open. Took me a while to figure it out but it works.
35helpful
3answers
Opening battery compartment on Midland LXT80 2-way radios
First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
Battery compartment in Magellan SporTrak
I used a Dremel Tool with a small drill bit to drill it out without killing the threads. It then popped out. My only problem now is finding a screw that fits the threads....
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
Jesse Walters
Jesse Walters
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
