View and Download Durabrand CD2775SW operating instructions manual online. 5-cd ... Stereo System Durabrand 5 CD Changer Home Stereo System Operating ... PRECAUTION Follow the advice below for safe and appropriate operation.
If it isn't already cut, please do not cut the factory connector off the wires that plugged into the original radio. Instead, puchase the correct pigtail for your vehicle, it will plug right in to the connector from the factory radio and colored wires that match the wires on the deck come out of the pigtail. This simplifies everything and leaves you with the option of reinstalling the factory radio at a later point.
You should have a wire harness pigtail that comes with your kenwood. you can also purchase a harness adapter plug/pigtail at most audio auto stereo shops to fit your car make and model. Be sure to save the packaging because the plastic bag has the color/codes for the harness. This harness is designed to plug right into the factory plug inside the dash just like the stock radios do. All you need to do is splice the kenwood cables to the adapter plug pigtail you purchase for your car. match up each wire as described here: 1994 Buick Century Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange Car Radio Ignition Switched 12V+ Wire: Yellow Car Radio Ground Wire: Black Car Stereo Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 6 1/2′ Front Speakers Location: Doors Left Front Speaker Wire (+): Tan Left Front Speaker Wire (-): Gray Right Front Speaker Wire (+): Light Green Right Front Speaker Wire (-): Dark Green Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Brown Left Rear Speaker Wire (-): Yellow Right Rear Speaker Wire (+): Dark Blue Right Rear Speaker Wire (-): Light Blue
Stereo dealers have wire harness adapters for almost every make and model of car. It will come with a connector both with color coded pigtails that are usually prestripped. The package will described which wires go where and their color codes. The deck you bought should have a pigtail with color coded wires and they'll match up to the ones on the harness adapter for your car. After connecting them all properly, you can take your deck with the attached pigtail and plug adapter and plug it directly into your car stereo plug where your old radio was connected...don't forget the anntenna lead as well... Not to difficult...email if you get stuck... KEN
