Question about Fedders Dehumidifiers
Model# a6dh50b2a. Bucket empty. Why does full bucket indicator light up and unit turns on and right off?
Posted by shelli Taylor on
Tom Chichester
    Top Expert:
  • Fedders Master
  • 57,273 Answers
This can be a fault of the internal interlock (switch) that is closed when the bucket is in place. Normally, the purpose of the interlock is to prevent the dehumidifier from mindlessly dumping condensate into a missing bucket.
Posted on Sep 21, 2015
How to trouble shoot our dehumidifier.
well this might be a small shortcomming of this model but as silly as it sounds even if you use a external hose to drain water from unit the float inside bucket still is active in unit so i bet if you look carefully the little float in corner of bucket is Just " not quite right" a little adjustment of this and im sure you can get it running again
Oct 20, 2014 | Haier HD656E Dehumidifier
Why is the empty bucket signaling full bucket
See if there is a float switch in the unit that may be stuck.
Aug 31, 2014 | Zenith 30 Pint Dehumidifier ZD300
The light indicating that "bucket
This usually happens when either the Float Valve in the bucket is stuck in the UP position (if yours is so equipped. Jiggle it to get it to return to the DOWN position.
If you humidifier's bucket is not so equipped. It's usually an indication that the bucket was not reinstalled properly, after it was removed. To check and correct this, turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the bucket and reinsert it, making sure that it fits "squarely" in the bucket holder from Top to Bottom. Once installed, make sure the bottom of the bucket is not tilted down in any way. Plug the unit back in and turn the Master ON/OFF Switch to ON. If it was reinstalled correctly, the bucket full light should have gone off and the unit will run as it should, if the humidity extraction level is set low enough.
Hope this helped you to troubleshoot and solve the problem.
Jun 23, 2011 | LG LD40E Dehumidifier
The unit is showing "full
Two things generally cause this problem. If your unit has a Float Valve inside the bucket, it's stuck in the 'Up' position, which under normal conditions, indicates to the unit, that the bucket is FULL. If you don't have that, then when the bucket was last inserted into the bucket holder, it did not trip the bucket removal safety switch. Remove the bucket and reinstall it, making sure that it fits squarely into the hole from top to bottom. Leave the unit ON when you do this, because if you do it correctly, the unit will automatically start and run. Also, be sure that humidity extraction level is set on 32 - 35 %.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Comfort-Aire BHD-651 Dehumidifier
Even though I have emptied the bucket the bucket full light will not turn off and the dehumidifier will not reset. I tried unplugging the unit but when I plug it back in it still says bucket full
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 29, 2010 | Haier 45-Pint Dehumidifier
The bucket full light blinks even though it is empty and there is "01" in the screen where the digital humidity level is indicated. Pushing the up or down arrow does not change the "01" number. Unit won't...
Take out the bucket and locate the bucket full switch inside the cabinet. Depress the switch and see if it comes on. If so, you may have to add a shim to the bucket or strap it in with a bungie cord as the bucket is jiggling and makes the unit think that it has been removed.
Jan 02, 2010 | Kenmore 54701 Dehumidifier
Dehumidifiers Logo
185 people viewed this question
Top Fedders Dehumidifiers Experts
Brad Scarpetta
ray gallant
Tom Chichester
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
