Question about Precor 546 Elliptical
When I turn the machine on, the display does not come up properly. Everything is jumbled.
jan wessels
    New Friend:
    Problem Solver:
  • 5 Answers
Internal memory: approx. 14MB, SD memory card
Posted on Sep 20, 2015
Top thread is fine bottom thread all jumbled
I've had the same problem - jumbled threads on the underneath side of fabric. My solution was this: I had recently purchased new bobbins and they turned out to be the wrong size. I went back to the ones that came with the machine and the problem disappeared. So, have you recently purchased new bobbins? They might not be the correct ones. Funny, in all of the posted possible solutions below, not one mentioned this possibility. turns out my new ones were not as tall and were slightly concave instead of taller and flat. Check your machine manual for the correct bobbin part number.
Nov 23, 2011 | White Sewing 2037 Mechanical Sewing...
Hi, I'm trying to sew a silky fabric and the stitches on the bottom keep getting jumbled and the top thread breaks
My guess is that you have lost all of your upper tension and you may have your needle in backward.
Unthread the machine.
Raise the presser foot. Turn the handwheel until the take-up lever is at it's highest position. Set the upper tension dial/knob to 5. Remove the needle and replace it making sure that the flat side of the needle shank is to the back. Thread the machine.
With the presser foot up, the upper thread should pull through easily and then grab when the presser foot is lowered.
Test sew.
The upper tension pulls the stitches up and the lower tension pulls the stitches down. When they pull properly, the stitch is even.
Oct 29, 2010 | Husqvarna Huskystar 215 Sewing Machine
Bottom thread is so sloppy
Are you sure the machine is threaded properly? Try tightening the tension. And make sure the bobbin was wound in the correct direction.
Aug 01, 2009 | Kenmore 12102
Whenever I sew on medium weight material, the bottle thread is all jumbled up. I've rethreaded the machine several times and have changed the tension and nothing works..
Most often it is top threading, if you are sure it is correct then there is probably thread wound around a rubber wheel which meters out the proper amount of thread for each stitch. Face palte and top must be removed for access.
Jul 10, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
Jun 13, 2009 | Heating & Cooling
Thread problems
you need to take out the thread and and bobbin thread and re-thread your machine...take the bobbin out of the casing and replace it properly...now turn off your machine wait 30 seconds turn back on and sew on scrap piece of fabric
May 22, 2009 | Bernina Sewing Machines
Jumbled screen on LG CU515
Your phone has a LCD (liquid crystal display) and if it is dropped or gets a chemical or even water on it it can damage the fragile insides of your phone. Is there a gas at the shelter that could be affecting it? Barring that, take it to your provider and have them analyze the problem. That is a free service. Good luck.
Feb 19, 2009 | LG VX8100 Cellular Phone
X85 lexmark
Under file menu find page setup. Check the margin settings. Compare them to the ones that are in the printer properties. If they are different the jumbled characters are caused by conflicting settings. Try returning to defaults. If this does not solve the problem, check to see what fonts you are using. A page written in a font not supported by your computer will usually display with small boxes or crazy looking characters.
May 19, 2008 | Lexmark X85 All-In-One InkJet Printer
Loose stitches every 1
test it out on 2 pieces of material by rotating the wheele by hand. pay close attention to the 1" area. when you turn it by hand you can feel the area of question. is your bobbin spooled correctly. if all fails read the directions.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 16, 2008 | Janome Memory Craft 9000 Computerized...
Precor 546 Elliptical Logo
55 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
