Question about Panasonic Viera TH-42PZ80U Plasma TV
Why is Power indicator light blinking
Power will not come on
Posted by Cynthia Boutilier on
    Top Expert:
  • Panasonic Master
  • 76,407 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Posted on Sep 20, 2015
What does the red blinking lights on the "standby"
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 18, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
When i turn on my tv the little red light blinks. THen the sound comes on but no picture. After a couple of seconds the red light starts blinking again and the standby light comes on and then nothing.
Jul 16, 2011 | Sony KP-51HW40 51" Rear Projection...
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have five (5) blinking lights from the standby lamp, what does it indicate?
Jan 28, 2011 | Sony KDS-R50XBR1 50" HDTV
No power only plug light and battery light is on
The lights are indicators of which operation does your laptop operates.
1. Power indicator is lighten to green meaning you are in the mode of charging your power.and if the power indicator turns to orange meaning you are now using battery power or the charging is finished.
2. Reading indicator is blinking meaning your laptop is currently processing but if the Reading indicator is not blinking and made a static light then your system is in hang up or not reading the processes.
3. Wireless indicator is blinking or lighten then you are in the a wireless mode connection. Also the bluetooth and Infrared connectivity.
So please check which light indicator is lighten when you on your laptop.
Thanks
Aug 06, 2009 | Toshiba Satellite M115-S3094 Notebook
Blinking power indicator light
When TV indicator light is blinking and after that the power will cut off. First you need to check the power board. But I am still need more details of your tv. please call 323-767-6030 and I will go through thes trouble-shooting, with you.
Mar 08, 2009 | Astar LTV-32HBG 32 in. LCD Television
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Power light blinking
I have a Toshiba 42H81 that has the power indicator light blinking and the TV will not turn on
Oct 14, 2008 | Toshiba 42H81 42" Rear Projection...
Indicator lights are blinking.
The Indicator Lights On The SC-X105L External Cam Are Blinking And Will Not Power Off. If both of the indicator lights on the external camera module blink and the external module cannot be powered off, this indicates that the batteries are in need of replacement.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Panasonic Viera TH-42PZ80U Plasma TV Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
