More than likely the contact points in the unit contactor are pitted and stuck together. When the control voltage is removed by the satisfied thermostat, the stuck contacts will not allow the system to shut off.
A tap with the handle of a screwdriver will usually jostle the stuck contacts loose....but they will stick together again fairly soon. The control more than likely needs to be replaced.
Unless you are fairly comfortable around exposed electrical wiring, it is recommended that you call a competent service technician.
Here
is a tip that explains what can be happening to make the dehumidifier
show that the bucket is full when it is not.
Dehumidifier
Problem It shows Bucket Full
heatman101
