Question about RCA DRC8300N DVD Recorder/VCR
DVD recorder/VCR combo DRC8320N
The panel does not stay on all the time. when it does nothing ejects but when i put a vhs tape in it plays. the remote cannot control anything. i think it might be the cord but i'm not sure because when the panel does light up nothing works right. do you think you can help me.
Posted by frustmom on
  • 3 more comments
  • Bout2switch Apr 06, 2008
    same problem as frustmom.
    same problem
  • Cynthia Garcia May 30, 2008
    My DRC8320N does the same as Frustmom's. I thought it might be the cord, so I plugged it into different outlets but that did not work. I may open it up and see if I can fix it, I'm sure it can't hurt.
  • Anonymous Jul 15, 2008
    Will not power on
  • Anonymous Dec 08, 2008
    MINE IS THE SAME
Anonymous
Same with me
Posted on Dec 07, 2008
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Tape keeps ejecting
You can check tape player for any type of object lodged in it. Maybe unplug and turn upside down to here anything inside. Or even any broken tape that come off inside. The only other thing is that the belts inside are worn and will not put device back in play mode.
Dec 22, 2007 | Sony SLV-N55 VHS VCR
My Panasonic Omnivision VHS won't eject
take the top off and eject it manualy, there is nothing else u can do with replacing a part, (small white spring loaded, ) probabaly
May 09, 2009 | Zenith ZHX-313 System
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
Entire front panel does not work, but responds to control.
have you pulled the plug from the wall for a few minutes?
also, some vcrs will eject the tape when the RECORD button is pressed on the remote, and a tape is inside that has the record tab REMOVED!
good luck
Feb 07, 2009 | RCA VR622HF VHS VCR
No remote for Goldstar 8mm VHS VCR recorder player
I have an extra remote to that unit if you would like to buy it. [email protected]
Dec 06, 2008 | Goldstar GVR-DD1 VHS VCR
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
VCR tape won't eject
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
RCA DRC8300N DVD Recorder/VCR Logo
209 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
