Question about Daewoo Refrigerators
I have a daewoo erf334m the freezer wasnt getting down to temp , so I stripped the partition at the back of freezer and only the top coil of the evaporator was caked in ice Any ideas guys
Posted by Lee Davies on
John Tripp
  • Daewoo Master
  • 4,656 Answers
5 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: drs2662aw amana side by side
Sounds like you may have a restriction or blockage, may also be low on freon
Posted on Aug 25, 2007
the dr
joey shearer
  • 447 Answers
SOURCE: Defrost condensate not draining
Make sure the water goes down the drain quickly. If the drain is a little clogged it may not be draining fast enough, letting it freeze before it drains. I use compressed air at a low psi to clear the drain from the freezer compartment. Does the refrig have an ice maker?? If the water is spilling over the fill tube behind the freezer panel it will also ice over the drain. Also sometimes drains just ice up for no apparent reason. I deice them and then they work fine. You can also take a piece of romex wire (the solid copper strand type) use the ground wire (bare copper) or strip the insulation off the black or white wires and loop the wire over the defrost heater and down into the drain hole. This will help any ice that builds up around the drain to melt in the defrost cycles. Let me know how it turns out.
Posted on Nov 19, 2007
carldc3
carl carpenter
  • 82 Answers
SOURCE: the coils are frozen solid in freezer behind back wall
frozen coils not always means freon problem. low air flow across evaporator coils could cause freeze up. if door is opened and closed an abnormal amount could cause a freeze up or even something pushed up against the air intake in the refridgerator. i would thaw it out completely and restart it, theres a chance it was nothing major. good luck
Posted on Jan 12, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Posted on Aug 26, 2009
Anonymous
  • 15 Answers
SOURCE: Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Posted on Dec 15, 2009
Overheating of Partition in a side-by-side
pull off the bottom front kick panel and check the condenser coil to see if it's filled with dust,also pull out the machine and remove the back bottom panel and make sure the condenser fan motor is running and clean out any dust back there,if the coil is clogged with dust or the condenser fan motor isn't working is what could make that strip hot.
Aug 30, 2012 | Whirlpool Refrigerators
Daewoo No frost multiflow fridge freezer. Freezer works fine. Light comes on in fridge but it is not getting cold. What can we do? Is it broken or is there a magic switch somewhere? many thanks
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 16, 2011 | Daewoo Refrigerators
I have a ge sxs model #gss22jepcww fride not cooling i removed panel in freezer to inspect coils coils are froze up around coils,I thinking its a frost free problem this model has a circut board in back is...
If you have cold temps and humidity sometimes the coils freeze up and you need to unplug your refrigerator until the ice on the coil melts, clean the coils and plug in, you may overflow your condensate pan, so you might need a towel if it does.
Jan 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature swing specification in a chest freezer.
It depends on the control that your freezer utilizes.
If your temp control dial has the numbers 0-9 or 1-9, then you have whats commonly known as a coil temp sensor.
Unlike an air temp contol that measure the air temp inside the freezer and comes on and off with a 3-5° swing, the coil temp sensor runs a little bit different.
With a coil temp control or sensor, the temp control has a capillary tube and bulb that is inserted into the coil either at on of the ends down a guidetube or just into the center of the radiator type fins. This temp control measures the temperature of the coil, and not the temperature of the air inside the freezer. When the unit runs, the coils typically gets 20° colder than the air temp. And when the control satisfies (shuts off), it will not call for cooling again until the sensing bulb has reached the cut-in point which is typically well above design box temp.
So, to quickly answer your question, yes it is possible to have a 25° temp swing and not have anything really wrong with the unit. That is how its been designed to operate and that is how it will operate. Your only option (although not recommended) is to replace the coil temp sensor with and air temp control. That will give you more consistent temps.
Also, when taking temp of a freezer with a coil temp sensor, be sure to temp the product in the freezer and not the air temperature.
Jan 01, 2010 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
I have a GE GZH22KGRB that is no longer as cold as it should be. Both Fridge and Freezer are working but poorly. I do have some frost build up on the back of the freezer. Defrost Thermostat?
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off at the set temp .
Nov 14, 2009 | GE GSH22KGR Side by Side Refrigerator
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Refrigerator in garage
Yes it is very possible that exactly what you are describing can be happening. Also try a thermometer frozen in a cup of water to get more accurate temps. Also 33 in the fridge is very normal for the cold control set on max and the heater installed. Let me know the temps in the frz with the thermometer sensing product temp not air temp which fluctuates often.
Dec 22, 2007 | Frigidaire FRT21P5A Top Freezer...
Refrigerators Logo
61 people viewed this question
Top Daewoo Refrigerators Experts
Lawrence Oravetz
NOEL
NOEL
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
