Televison & Video Logo
A
Anonymous Posted on Sep 18, 2015
Our LG 47LE5400 screen went black this morning, is the problem the main board, power supply or hopefully not the LCD panel?
The only thing that lights up are the TV buttons on the bottom TV frame (Power button, menu button, vol up, etc.). After the buttons light up for a few seconds, only the power button and the LG light stay lit until we shut off the TV with the remote or by pushing the frame power button. The screen stays black, no backlights are seen with or without the cover on, no images are seen using the flashlight test, no sound, nothing. We can not see any obvious burn marks or bulging components on the front or back of the two panels (power supply panel (part number EAY60803401) w/built-in invertor and LED drivers, main board panel (part number EBU60884302) w/built-in T-Con). Any ideas what to try or test next to eliminate a bad LCD panel?
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Sep 19, 2015
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003370
Points
237762
Sounds like main board fault.
Testimonial: "Thanks for your suggestion, before spending any money replacing the main board, is there any test we can do to ensure that the lcd panel is not bad; we don't mind spending the $$ to replace the boards, we just want to make sure that our panel itself is still ok"
  • Anonymous Sep 19, 2015
  • The Knight
    The Knight Sep 19, 2015
    Hi The main board have no repair. Only replacement can be done; because, in most cases ii will be multi-layered circuit board. Very like the computer motherboards. I think you did got its complication. No fault to the display panel.
1helpful
2answers
Why does my TCL tv stay dimmed and very dark screen? I've reset it and everything?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2answers
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2answers
I have an Element tv that has no picture, good sound but basicaly a black screen. Do i need a didgital board or a main board?
My lg smart tv model -47le5400 it turns on but the screen is black buttons light up but no picture
Lg lcd tv screen went black after some snow on the screen but there was still sound, then hour later turned it back on tried flashlight test and saw channel # with light then the picture came back
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
My LG LCD tv's picture went black.
Lg 47le5400 tv has no picture or sound
Contact any service technician. To get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
The screen will turn on, but after 2 seconds the screen goes black, the power button stays lit, and sound remains. What could this be?
it could be a bad CCFL lamp, inverter, power supply 24vdc output, or a main board problem. The set will need to be properly diagnosed.
19 inch lg flat screen tv wont turn on
Power Supply board is dead.Tries Websites Shopjimmy.com,Ebay.com.Buy a refurbish power supply board for the replacement.
Power went out on LG lcd tv
Those units usually have a main board that all the functions are centralized on. If the LED comes on then your power supply is operating (at least no shorts). But the main board will most likely be the problem.
C-Dog
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
