Question about Audio Technica Audio Players & Recorders
Audio Technica AT-LP60 Non-USB Turntable.
What is the way to spin at 78 rpm?
    Top Expert:
  • Audio Technica Master
  • 66,557 Answers
Quite likely there is no way as 78's are OLD .
Posted on Sep 17, 2015
I have a LP60 USB and theres a burning smell coming from the platter?
You mean while playing a record?.... I shall tell you a secret, eveytime you needle plays a record, it melts the vinyl a bit , just like that you can ice skate and melt the ice through the pressure.
But if you smell your vinyl then your needle is installed very wrong.
And needs to be replaced.
Pls read this http://www.whathifi.com/how-to/how-to-set-turntable.
if you smell your platter, without playing a song , you have to watch if. it spins at normal speed without variation, then you can remove the platter and give your bearing one drup oil. But that ain't the problem.
you have to smell the motorunit, since it's a cheap turntable and ain't having good components, but start with following that link i gave you and you only have a motor with some electronics , a belt
and a bearing with a platter and in your case a builtin usb and phono-amplifier which are useless, because the quality is way too low. not much can go broke.
Mar 22, 2015 | Audio Technica USB Turntable
Pl60 not starting
Check 1) Power supply (Don't get mad I had to travel 250 miles to turn a key switch) 2) Start switch and levers for adjustment 3)Belt is it on or maybe stretched 4) Spindle binding 5) Does the platter turn freely
Feb 10, 2014 | Urban Outfitters Audio-Technica AT-LP60...
I bought an Audio Technica AT lp60 belt driven turntable.I live in australia and made the mistake of plugging it straight into the wall with a power adaptor now it won't turn back on. I think I blew the...
Once you find the fuse just take it out and go to your local electrical parts shop. Your looking for the type that sells transistors etc. They should sell you one.
Aug 31, 2013 | Audio Technica Audio Players & Recorders
My brand new audio-technica AT-LP60 turntable has skipped on every single record I've played in it (even brand new ones). Always happens at the same spot - towards the end of the record, halfway...
hi,
Do one thing adjust counterweight on the back of the arm to 1.5gm or 2gm by rotating the counterweight. It will give some more pressuer on the styles and will avoid the jerking
ok
Aug 04, 2011 | Audio Technica AT-PL120 Turntable
I have installed the AT-LP60-USB turntable into my computer via USB/ The Audicity program is installed as per the directions. Everything is working well - turntable, Audicity, etc. However, there is no...
You have to listen through the Audacity software. Once you start Audacity, click on the down-arrow on the toolbar next to the microphone symbol and choose Monitor Input. You will need to do this every time you start Audacity.
Nov 07, 2010 | Audio Technica USB Turntable
Brand new audio technica at-pl120 turntable not powering on; cant get turntable to spin
HELLO!
I don't know which country you are from, but if the mains plug has a fuse in it then replace it with the same type. If that does not do the trick take it back back where you bought it and get a refund or a replacement! There may well be an INTERNAL fuse inside the unit on the power supply unit which may be at fault. If it is under warranty don't open the turntable yourself - take it back - I WOULD!
All the best!
Jul 12, 2009 | Audio Technica AT-PL120 Turntable
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
Audio technica lp 20 usb the belt is out of place and I do not know how to put it back as it was
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Oct 11, 2008 | Audio Technica AT-PL120 Turntable
207 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
