Question about Realspace Mezza L-Shaped Glass Computer Desk, 30in.H x 61 1/2in.W x 61 1/2in.D, Black/Chrome
How do you square up the frame so that the glass top will fit properly?
Posted by wayne dunn on
Claude Kayser
    Top Expert:
  • 9,098 Answers
In geometry you measure an angle of 3 by 4 and the diagonal will be 5 at the meeting points
The base will be 90* the sharp angle 30* and the other angle 60*
That is the easiest way to project any frame.
Posted on Sep 17, 2015
Suction cups for desk glass top where to find replacements
Hello @Luis Vinuela
If this is for a GPS, as this is the category where your post was found, then try gadget electronics shops that deal in GPS products.
If it's for a glass top plate of your desk, a hardware store may keep something like bathroom suction cups that you can modify to fit.
Depending on how the desk is made, you could also use double-sided adhesive foam-tape, or squares, also called 'grab-tabs'.
Jul 10, 2018 | GPS
Window will go down buto won't go up
Hello -
I have had the same problem with car power windows more than once.
The problem could be the motor which runs the power window or the frame holding the power window or both.
Personal experience: Getting the power window problem properly fixed is expensive. For me, the last time it was done on my Volkswagen, 2 years ago, it cost $800.00 (US).
Jan 12, 2018 | Cars & Trucks
How do I fit legs made from same 25mm square tube as top section from moving from 90 degree angle as I weld ?
couple of methods
use a section of the square tube as a block across the frame and clamp to the leg and to the frame the leg is being welded to ( that holds the leg square to the frame
now tack weld along the length and not across the frame
the problem is that when you weld across with out tacking both sides first , as the weld cools down it pulls the leg in that direction and the trick is to prevent that action by tacking both sides first before welding properly
welding across the tube will tend to bend the frame as well and by welding along the sides of the frame after tacking inside and outside first that stops the from from bending
mostly a weld on both sides of the frame rail onto the leg will be sufficient as it is not really necessary to weld all the way around the leg
Apr 25, 2016 | Welding Tools
How can I square it up so that the glass fits properly?
Measure corner to corner diagonally. The numbers will match when you have it squared up.
If you need to square up a 2 piece desk, measure the desk, loosen the joint and add spacers as needed. Retighten the joint.
Sep 16, 2015 | Realspace Mezza L-Shaped Glass Computer...
Glass lid fit is not level, how can it be adjusted?
The glass lids usually sit in a frame with a sealant under them, you can remove and reset it carefully by using two small screwdrivers to go around the outside using the screwdrivers to (gently) like tyre levers lift it out. Take your time doing this be gentle and it will come out then put it back in square.
good luck Ray
Aug 11, 2014 | Rangemaster Classic 110 (Dual Fuel) Dual...
Spartan brand curved glass shower door installation info needed.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Aug 27, 2009 | Sterling Plumbing Sterling& By-Pass Shower...
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Cleaning inside glass door, kitchenaid range
you do no tneed to remove the top to release the glass, yea aslong as the lower trim is removed then the only thing holding the glass, is the grease/sticky rubber gaket. lift up from the bottom slightly and twist out from the tabs. just be carefull when cleaning inner door glass, those "ridges in the paint, are just that paint, so dont use anything abrasive, youll ruin the finish!
Oct 30, 2008 | KitchenAid KGST307 Gas Kitchen Range
Shattered glass top for Hotpoint range/ how to replace
Hi there!
There are two basic types, Flush fitting and framed.
The framed versions are a bit like a picture frame, with the fixings around the edge and back. The flush ones rely on adhesives to the base edge around the plate, but may have a metal fixing frame attatched already.
Check the new plate you have to see if there are any keyhole shaped slots on a subframe (indicating a drop on, and push forward to lock arrangement) or if it looks different to the one that is broken.
The old saying - "If in doubt- ask" is true here, and you should telephone the manufacturer for any specific fitting instructions. You may need additional parts - fixing plates, screws, seals or adhesives, so I would advise calling their service department to ask if additional parts are required for fitting.They should be happy to supply them if needed.
This is not a cheap item, so don't risk poor fitting or damage by lack of correct parts.
Jun 15, 2008 | Kitchen Ranges
Realspace Mezza L-Shaped Glass Computer Desk, 30in.H x 61 1/2in.W x 61 1/2in.D, Black/Chrome Logo
124 people viewed this question
Top Realspace Computers & Internet Experts
Redhatchris
Level 1 Expert
Tom Chichester
Are you a Realspace Computer and Internet Expert? Answer questions, earn points and help others
