Question about Realspace Mezza L-Shaped Glass Computer Desk, 30in.H x 61 1/2in.W x 61 1/2in.D, Black/Chrome
How can I square it up so that the glass fits properly?
Posted by wayne dunn on
David Shaub
    President:
  • 2,976 Answers
Measure corner to corner diagonally. The numbers will match when you have it squared up.
If you need to square up a 2 piece desk, measure the desk, loosen the joint and add spacers as needed. Retighten the joint.
Posted on Sep 20, 2015
Suction cups for desk glass top where to find replacements
Hello @Luis Vinuela
If this is for a GPS, as this is the category where your post was found, then try gadget electronics shops that deal in GPS products.
If it's for a glass top plate of your desk, a hardware store may keep something like bathroom suction cups that you can modify to fit.
Depending on how the desk is made, you could also use double-sided adhesive foam-tape, or squares, also called 'grab-tabs'.
Jul 10, 2018 | GPS
How do you square up the frame so that the glass top will fit properly?
In geometry you measure an angle of 3 by 4 and the diagonal will be 5 at the meeting points
The base will be 90* the sharp angle 30* and the other angle 60*
That is the easiest way to project any frame.
Sep 16, 2015 | Realspace Mezza L-Shaped Glass Computer...
I bought a new interlocking collar for my Kitchenaid blender, and now it doesn't seem to be fitting on the base properly. It's resting on the base rather than going all the way down, if that makes sense....
Remove the collar from the jug and have a good look inside, there is a circular ring inside the collar that needs to engage correctly with a glass finger on the jug. The glass finger goes between 2 plastic fingers. I think there are two of them. It was a silly idea that's been given the flick on later models.
Mar 02, 2015 | KitchenAid KSB560 5 Speed Blender
Glass lid fit is not level, how can it be adjusted?
The glass lids usually sit in a frame with a sealant under them, you can remove and reset it carefully by using two small screwdrivers to go around the outside using the screwdrivers to (gently) like tyre levers lift it out. Take your time doing this be gentle and it will come out then put it back in square.
good luck Ray
Aug 11, 2014 | Rangemaster Classic 110 (Dual Fuel) Dual...
Need to know parts swap. can 2000 jeep cherokee dorrs fit and look right on a 1996?
no, the 2000 jeep grand Cherokee is a little bit more round when the 1996 is a little bit more square. the door will not fit properly
Apr 28, 2011 | 2000 Jeep Grand Cherokee
How do i replace the oil gauge window on my zzr1100
hi, you can do this with the case still fitted to the machine, but it may be best to remove the case to save any broken glass contaminating the oil, with care break the glass and prise out the old window, take care not to damage the hole the glass sits in, clean up before fitting the new glass, some glass windows come with a band of sealent around them , if this is not the case, apply a small amount of sealent not silecone, and carfully push in the new window untill home,take care not to damage the window outer ring keep checking as you push in that it is square and allter position by pushing on opposite end until square, easy job, requires some finness
paul
Feb 03, 2011 | 1996 kawasaki ZZR 1100
A window glass 4 ft. 2 in. by 2 ft 10in. find its area. show the figure
Below is calculation of window glass area :
4.167 ft '------------------------------------'- ' ' ' ' 2.833 ft ' ' '------------------------------------'--
Total area = 4.167 ft x 2.833 ft = 11.81 ft2
Dec 04, 2010 | CRL Fixed "All Glass Look" Window for Side...
Need to replace Panasonic NE8070 model, 15in dia,microwave plate
hi my name is mark, i found panasonics part website follow link http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp?validate=1 if this helps please rate how i did. thanks for you question.
Mar 18, 2009 | Microwave Ovens
Optic lens tube separation
image.php?productid=16148sir,your microscope tube with the eye piece is screw joint with microscope body. Rather part is friction fitted as well as there is a proper place to mount it.you can do the gluing but first of all be clear that part should be not a movebale part other wise you will have dificulty for fine focusing.
for the further quotation dont be hazitate,
INDRAVIJAY
Feb 13, 2008 | Tasco 750 Monocular Microscope
Realspace Mezza L-Shaped Glass Computer Desk, 30in.H x 61 1/2in.W x 61 1/2in.D, Black/Chrome Logo
201 people viewed this question
Top Realspace Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Realspace Computer and Internet Expert? Answer questions, earn points and help others
