Question about HP Photosmart 3310 Printer
Error HP Photosmart 3310. No strart print, no scanning...
HP Photosmart 3310. Ink system has failed. Unable to copy, receive faxes, or print Error: Oxc 18a 0106
Posted by rstm12 on
  • 11 more comments
  • Anonymous Dec 12, 2007
    I have the same problem, but on HP Photosmart C6180
  • Henny123456 Jan 14, 2008
    I tried unplugging the power cord and remove all cartridges and place them back after a few minutes....no result...still the same error message OXc 18a 0106
  • Anonymous Aug 17, 2008
    c6180 error oxc18a0201
  • arbrennan Aug 18, 2008
    The printer will not print. It tells me that "the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume." Twice I have installed a new genuine HP cartridge (light cyan), but the problem persists. The contacts on the cartridge and the pins in the cartridge socket seem to be quite clean.
  • ife5530 Oct 14, 2008
    I have e HP Photomaster C5180 All in one, I changed the cartrige and after that the printer only send the mensage "Error 0xc18a0101" and the printer dont work.
    Please, colud you help me with this issue?
  • Anonymous Mar 08, 2009
    When you try to print anything the dumb code comes up and tells you to shut down and then turn it on again, it doesn't work. =[
  • Anonymous Apr 26, 2009
    same problem keep getting an error message ink too low i changed it twice still wont work ???
  • Anonymous Apr 30, 2009
    I have the same problem with my printer. I contacted HP for some help in troubleshooting this error and they said that I was past my warranty and need to purchase a new printer. There is basically no way to fix this error. I purchased an entire set of new ink cartridges because that was one troubleshooting idea but don't waste your money unless you are still covered by your warranty...
  • Anonymous Mar 13, 2014
    ink system failed on HP Photosmart 5150
  • Anonymous Mar 22, 2014
    ink system has failedunabledto copy,receive faxes or print.
  • Anonymous Mar 24, 2014
    Don't print magenta ink
  • Anonymous Mar 27, 2014
    Ink system has failed unable to print
  • Anonymous Mar 30, 2014
    ink system failer
Anonymous
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Posted on Feb 20, 2008
sherwin
    New Friend:
Where can i find black and color button? thanks b110a series... im trying to reset but didnt work. please help. ty
Posted on Sep 26, 2011
scookieman
    New Friend:
    Problem Solver:
T,THROW IT AWAY, GET A NEW ONE-----------
Posted on Sep 21, 2011
Anonymous
    New Friend:
I replaced all cartridges and still got the error message 0xc1810206
Posted on Mar 11, 2010
Anonymous
I work for HP Tech Support, the official word here is that if you are receiving this issue with a 3300 series, your printer is having a pump issue and will need to be replaced. There is a firmware upgrade to fix this issue on 8250's at:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ps-40971-1&lc=en&cc=us&dlc=en&product=443024&os=228&lang=en
Posted on Mar 13, 2008
Anonymous
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartidges in the printer so that it can reset. Good Luck!
Posted on Jan 31, 2008
  • quint450 Jan 25, 2014
    Best remedy ever!! Thanks a million!
I have an HP photosmart 3310 printer with an error message: INK SYSTEM HAS FAILED. UNABLE TO COPY, RECEIVE FAXES, OR PRINT. REFER TO PRINTER DOCUMENTATION. ERROR: 0xc18a0106 This comes on whenever I...
Why dont you try uninstalling this form your PC/laptop and reinstalling it again.
This should help restart the printer again.
Good luck and thanks for using Fixya
G.
Jun 14, 2011 | HP Office Equipment & Supplies
Ink system failure
I have a message on my printer
Ink System Failure
ink system has failed -unable to copy, receive faxes,or print.
error Oxc19a0107
Feb 10, 2011 | HP Photosmart 3310 Printer
I have a message on my printer Ink System Failure ink system has failed -unable to copy, receive faxes,or print. Refer to printer documentation error Oxc19a0002
Hi
Please do this and let me know
Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in.
Let me know or Call +877 889 6859
Jan 06, 2011 | HP Photosmart 3310 Printer
Getting "ink system has failed. unable to copy, receive faxes or print. error:0xc18a0106. all cartriges are new
Hi ,
There are a lot of error codes depending on the printer that you have so here is a document that would help you take care of it and is an hp document.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=439491
all the best.....
Mar 25, 2010 | HP Photosmart 3310 Printer
I am getting an error message on my HP Photosmart 3310 as per below: INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013...
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 24, 2009 | HP Photosmart 3310 Printer
normally in this scenario the whole printer needs to be replaced..
Oct 22, 2009 | HP Photosmart 3310 Printer
Photosmart hp 3310xi - ink failure???
Perform the steps given in the below webpage and if the issue persists then contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&cc=in&lc=en&dlc=en&product=439491#top
Jun 05, 2008 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
3,600 people viewed this question
Ekse
efs_perpends
efs_perpends
