Archos titanium 80 tablet
Flash it
chines tablet software
SOURCE: I received a new Archos 43 16 GB internet tablet
Can't exactly help you, but I'm in the same situation. I got a crack across the middle of the screen on my 43 while it was in my pocket. It seems like this might be a problem with the gen 8 tablets, but Archos is currently refusing to consider it defective.
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
It is a most likely a battery problem. Or humidity has gotten to it. It even could have over heated. To try to fix, replace the battery or place in a bag of rice if you think it got humidity in it. If none works than it is the software and it malfunctioned.
SOURCE: UNABLE TO LOG ON TO SLY ELECTRONICS 7" 4GB TABLET
Hold down the power button and the volume up button after shutting it off.
You might need to flash new firmware.
SOURCE: My xo tablet won't come on. The charge light will
Hi Holly, I will try and help, you will have to do a factory reset!
Hold volume up and power until you get recovery mode then using volume key to select wipe factory then click power then after finish select wipe cache then reboot.
Post back with result or if you need more help.
