Clicking sound plus smell of motor and overheating on 2 with dough hook for bread. i am making 2 large loaves at a time.
The clicking sound started after the 3rd time making bread. The overheating and motor smell after 5th time. Each time I am using a dough hook for whole wheat bread - not a dry dough at all - very moist -
Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
It sounds as if the motor has burned out. You may need to purchase a new blender or send it to the manufacture for repair if it's still under warranty.
If the burning smells like plastic then the walnut shells most likely put too much strain on the motor and burned it out. If the burning does not smell like plastic then you most likely have walnut shell grit jamming your motor.
This can be cleaned out by first ENSURING IT IS UNPLUGGED FROM THE WALL.
First remove the canister (if possible)
The remove the blade (if possible) check for a build up of grit between the blade and the shaft connecting it to the motor.
Check the channel the shaft passes through from the motor for large chunks of walnut shells or date paste.
Clean the canister thoroughly with warm water and leave it to soak overnight in a water/soap mixture.
If this has not resolved the issue then try to claim it under warranty or source replacement parts online.
I have several recipes for bread both yeast and none. But not enough space here.
French Bread.
Use C blade. 3c plain flour.2Tbs rapid rise yeast. 3 Tbs sugar. 2Tbs salt
1c water. 2/3 c of milk. 3Tbs margarine or oil. heat together until 130F/55C add to yeast mixture and stir in with C blade add in an egg and stir.Empty onto a floured counter. Knead by hand for 8-10 mins cover and let rest for 10 mins.
Divide dough into 2, shape into loaves place on greased cookie sheet cover and let rise 15-30mins. Bak in a 400F/200C oven 18-20 mins until light brown,Remove cool and enjoy.
I work for Black & Decker appliances and have more than 10 years experience with small appliances.
Anytime you smell something burning while using an appliance that isn't suppose to heat food, something is wrong. You shouldn't smell any foul odors emanating from a blender. The fact that it shuts off while pureeing something as simple as oatmeal indicates that particular blender is defective.
If you contact the manufacture they will be able to inform you as to your warranty eligibility.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
