Question about Vizio E500i-B1 50-Inch 1080p Smart LED HDTV
How to fix black vertical line on LED tv caused by what looks like impact damage at the bottom of the screen?
Not sure how it happened, but one day we turned on the TV and it had a black line on one side of the screen. We reached out to Vizio, but they said that it was not covered under their warranty since it looks like impact damage. Unfortunately, we have no idea why or how the TV was damaged, there's no sign of impact damage when the TV is off. Here's some pictures of what the damage looks like: http://imgur.com/a/X55f8 Any help would be greatly appreciated.
5 Related Answers
Dewayne Turner
  • 87 Answers
SOURCE: vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 19, 2007
Dewayne Turner
  • 87 Answers
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Posted on Oct 23, 2007
Anonymous
SOURCE: LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Posted on Aug 24, 2008
Anonymous
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Posted on Feb 18, 2009
Anonymous
  • 56 Answers
SOURCE: HELP PLEASE Vizio Plasma tv broken again - possible driver board?
This could cause by the power supply or the mainboard.
- If the LED stay Green when you turn on the TV. But you can not turn it off, in this case the main board has failed. Replace the mainboard will fix the problem.
- If the LED light always stay at Orange, you can not turn on of off. In this case the mainboard also has failed.
- If you turn on the TV you will hear the power supply click on the LED is green then it click off the light turn Orange. In this case the power supply has failed.
Which boards did the repair shop replace?
Hope this will help.
I have an LG 47GA6400 TV. I have 2 large vertical lines on the screen. I need help identifying what is causing the lines. Could it be the t-con board?
PEOPLE, YOU MAY DON'T NEED TO BUY T-CON CARDS OR ANYTHING LIKE THAT, THE FIXING FOR THIS PROBLEM COULD BE VERY EASY, MOST OF THE TIMES IS A FAULTY CONTACT IN THE RIBBON CONNECTOR THAT FEEDS THE LED SCREEN AND THIS FIX APPLY FOR SO MANY BRANDS, MODELS, OR SIZES OUT THERE, GOOD LUCK!. DISCLAIMER: THIS VIDEO IS FOR REFERENCE ONLY AND I WON'T BE RESPONSIBLE FOR ANY FURTHER DAMAGES OR INJURIES YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!. THANKS FOR LOOKING.
SHOW MORE
HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55 MODEL LG 55LX6500
Jan 29, 2018 | LG Televison & Video
What causes my LG 55LS4600 55" tv to have sound but no picture.
It is a common problem for the LG model. The problem
is defective LED back lights ASSY. You have to open the display panel & replace the burned LED strips.
Jan 13, 2018 | LG Televison & Video
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
I have a vertical line on my lg led flat screen tv how could this happen? How can I fix it?
tv screens are filled with pixels that are set up in a long chain, one after the other after the other. sometimes one of those lines can get damaged from all sorts of things and cause a line to not work. thats the only idea i have but ive never heard of that being easily fixed
. best of luck
Oct 03, 2014 | Televison & Video
What should i do,model number below has vertical lines on half of the screen, any suggestions?
If they are blurry lines, likely you have a problem with heat damaging the diffuser plate behind the LCD. Unfortunately, there is no fix to this other than to replace the screen, which is as much as the same TV used. It's usually caused from the vents in the back of the tv getting clogged with dust/debris/smoke and the power inverter overheats. It causes the screen to develop a line on one side of the screen, then it starts to look like the screen was washed with something and you get black streaks running from the top which usually is accompanied by a darkened blurry "cloud".
May 08, 2014 | Seiki 32" LED TV - SE321FB
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Bottom of screen flickers, and eventually the screen 'freezes'
they have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
Jan 17, 2009 | Prima CV2011 TV
SONY 52" XBR5 Screen Damage
You are correct, the screen is damaged and in most cases cost mre than a replacement tv. There is no repairing a damaged LCD panel, just replacing.
Jan 31, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Logo
46 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
