You can skip tracing via texts or phone calls:
Phone calls: Local phone calls are answered more so prefer a mobile phone that allows you set up local phone numbers whenever desired.
Custom greeting messages: When a person doesn't answer the phone call, you are instructed to leave a voice message. Now, when the other person calls you back and your greeting message differs from the one that you had left in the voice message, he would straight away hang up your call.
Press the [Feature] [7] [0] (or simply press the [Transfer] button below phone display)
Dial the number where you want to transfer the call
Stay on line if wishing to speak to the person
Press the [Rls] button to complete the transfer
If an external call is transferred to a busy internal or network extension, or is not answered after a few rings, the call automatically rings you back.
Note: Use Link to transfer callers to a telephone number
Check Windows Sound mixer for application volume. Down in system tray at right side of taskbar double click sound icon for XP or click sound icon once and click Mixer for Vista. Look through volume settings for your phone application. Make sure it is not muted and volume is up.
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To send a call to another telephone within your system, or to an external telephone. You may not be able to transfer a call on an external line to an external telephone, depending on the capabilities of the lines. 1. Make or answer a call. 2. Press the feature button then press 70. 3. Call the person you want to transfer the call to. 4. Stay on the line if you wish to speak to the person first. 5. Press the Release button to complete the transfer. If an external call is transferred to a busy internal or network extension, or is not answered after a few rings, the call automatically rings you back.
This sounds like you have a call back message active on your phone, The callback is a through back to the days before we had Voice-mail, if you wanted a person to call you back you could activate their message light by pressing your message key while the called phone was ringing. To remove the light you would lift your handset and press the message key then select which party you wished to "callback", once the call was answered at the other end the light would be extinguished. Give this a try, I bet you will be surprised at the results.
check and see if the speaker located to the bottom of the main-board is place back in the correct slot if not put it in or replaced it....replaced also the cable/ribbon that is located on the lcd.
Unfortunately Microsoft's phone system at the call centre has this happen periodically. I have had to call back 2 or 3 times until I get a clear line and once I even waited a few more hours to call back until a different call center answered. Hope this helps
