Question about Kodak W730 PULSE Digital Frame
Cannot upload pictures to kodak digital pulse 7 frame. Says Java not loaded but it is.
Java loaded but says it is not. Can view pictures on frame but cannot upload
Posted by M book on
5 Related Answers
Anonymous
SOURCE: My kodak easyshare sv811 digital picture frames music not playing
Most files you download say from I tunes are "protected" files. They will not transfer. You have to convert it to an MP3 file. I found a free converter on the web that will convert your protected files to MP3 file then you can download it to your photo frame. i just bought one today and it took me ALL DAY to figure this out. What a PAIN! good luck!
Posted on Dec 22, 2008
Anonymous
SOURCE: kodak easy share SV 811
I had the same problem. I use kodak easyshare software and load my pics on to that. Then put all the pics you want in the picture tray. Have your frame plugged into the computer with your usb cord. Then go up to File menu and drop down to "copy to". On my computer it is Folder "E" which is the drive the frame is connected to. Then pick from the Resize drop down menu " best for picture frame', then click copy. You will see the program loading all the pics to E drive. When done, unplug usb cord and you will see it loading on your pic frame. As easy as this is to do, I found it frustrating as well, but when it works, it is easy. Hope this helps
Posted on Dec 28, 2008
Anonymous
SOURCE: Please help -
I don't have it fixed yet but think I am in the process. When I installed the firmware, it didn't install properly which I didn't realize. I have now uninstalled it and reinstalled. It should work now - fingers crossed. Thank you for taking the time to look into this for me. M.K.
Posted on Jan 30, 2009
leepania
Pania Lee
  • 1099 Answers
SOURCE: the kodak easy share digital picture frame won't show my pictures
Pls. check if there is any reaction when pressing the buttons onto the frame.
Check the batt within the remote.
Reset the frame.
If all fails:
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 15, 2009
leepania
Pania Lee
  • 1099 Answers
SOURCE: I have a Kodak P820 picture frame. I wanted to
OoW. repair
Price: 48,44 Pounds
Contact KODAK:
Posted on Oct 20, 2009
Picture frame screen turned blank
Yeah, they do that. There's a fix, but it costs more than the new ones. They're a lot cheaper than when you likely got yours.
Spend the money ... they're still cool.
Oct 13, 2014 | Kodak Pulse 7 in. Digital Frame - Black
Kodak W730 Pulse is not finding any wireless networks
I'm having the same problem so I'm trying to re register it but need the activation cade since I don't have the box anymore and it won't come up on screen
Nov 16, 2013 | Kodak W730 PULSE Digital Frame
Kodak pulse wifi problems
either you are not entering you web key for the wifi correctly or you have not entered the activation code for the frame which can be found when you hold the heath check button on the back of the frame
Dec 29, 2012 | Kodak W730 PULSE Digital Frame
Do not know how to transsfer pic fromcomputer to the Kodak pic frame
On one side of the frame there should be memory card slots and a usb slot.
two ways to do it, take the memory card from the camera and put it in the frame.
Or down load the camera to tyour computer and then with a usb cable upload the picture fram with the pictures you want
Or from your computer load a memory card and then stick it in the frame
Feb 20, 2010 | Kodak EasyShare SV811 (8858946) Digital...
How many pictures can the Kodak EasyShare SV811 hold at one time? I tried uploading around 30 picutres from my computer to my digital picture frame and only 17 of them uploaded. Did I try uploading too...
SV811 doesn't have a large enough internal memory thats why the picture capacity depends on the inserted SD card or if you transferre pics directly from the computer to display simultanously.
The frame should display as many as on the SD card.
Nov 30, 2009 | Kodak EasyShare SV811 (8858946) Digital...
How do I load pictures from the Kodak Gallery into my Kodak 811 frame?
You can use an SD card. Put card in pc, put pics on the pics file on card, then put card in the frame.
Nov 15, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Will Not View All Pictures In Photo Directory
Take the camera and tag the pictures and select all of them and tag/ favorite and protect and tag some more directories you can create. That will delay transfering the pictures but all of them will transfer to files.
Vitally
Mar 01, 2009 | Kodak EasyShare EX1011 Digital Picture...
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Kodak easy share SV 811
Aug 04, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Kodak W730 PULSE Digital Frame Logo
684 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
