Question about Dometic RM2652 Refrigerator
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
SOURCE: will not cool on electricity
Hi there. There are actually a few causes of your problem but I would begin by checking the fuse. here is the Dometic troubleshooting manual for your model. It should help.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Posted on Jun 04, 2009
SOURCE: warm temps cause cupboard shelf above refrigerator to heat up
well thats normal mate you cannot prevent this ... perhaps try draging your fridge away from the wall so it sits about 100mm off the wall
Posted on Nov 11, 2009
SOURCE: My Rm2652 Refrigerator in my Rv just quit cooling.
You need to have 12 volt supplied at all times to make it work
Check to be sure you have a good 12 + and a good ground.
Lots of times the coolant leaks without you smelling anything Slowly over time
Posted on Mar 11, 2010
SOURCE: everything in my Dometic
You need to lower the refrigerator setting down to 2 and make sure that the upper damper is working.
Posted on Mar 15, 2011
Sep 11, 2014 | Dometic RM2652 Refrigerator
Mar 20, 2010 | Dometic RM2652 Refrigerator
Mar 06, 2010 | Dometic RM2652 Refrigerator
Oct 23, 2009 | Dometic RM2652 Refrigerator
Sep 02, 2009 | Dometic RM2652 Refrigerator
Jun 03, 2009 | Dometic RM2652 Refrigerator
Mar 23, 2015 | Dometic RM2652 Refrigerator
186 people viewed this question
