Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
REFRIGERATOR GE MEDALLION 850
The heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
After letting it all thaw, I took the cover and the Styrofoam insulation and did not see anything that could block the air flow fan working.
I closed it all up everything started OK but after a few days it stated freezing again...
Can you help ?
Tks Richie ! Makes a lot of sense ! Is it easy to replace the element ? How does it look like ? where is it located ? Tks again MichelTks Richie ! Makes a lot of sense ! Is it easy to replace the element ? How does it look like ? where is it located ?
Tks again
Michel
The evaporator is usually behind the back panel of the freezer and it has to be removed to gain access to the coil. The defrost heat element is underneath it so that when it gets turned on it heats up the coil and melts the accumulated ice. This runs for maybe 15 minutes and if the temps get too high the defrost thermostat stops the operation and turns everything back on.
Has two wires going to it. Disconnect them both and do a continuity test on the coil. If open you will get an infinity reading. If you get a low ohm resistance reading, it is not the coil!The evaporator is usually behind the back panel of the freezer and it has to be removed to gain access to the coil. The defrost heat element is underneath it so that when it gets turned on it heats up the coil and melts the accumulated ice. This runs for maybe 15 minutes and if the temps get too high the defrost thermostat stops the operation and turns everything back on.
You can't post conmments that contain an email address.
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
One solution:
This can happen if door has been left open. To solve:
